High-resolution mid-infrared spectroscopy of buffer-gas-cooled methyltrioxorhenium molecules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue New Journal of Physics Année : 2017
We demonstrate cryogenic buffer-gas cooling of gas-phase methyltrioxorhenium (MTO). This molecule is closely related to chiral organometallic molecules where the parity-violating energy differences between enantiomers may be measurable. The molecules are produced with a rotational temperature of approximately 6~K by laser ablation of an MTO pellet inside a cryogenic helium buffer gas cell. Facilitated by the low temperature, we demonstrate absorption spectroscopy of the 10.2~$\mu$m antisymmetric Re=O stretching mode of MTO with a resolution of 8~MHz and a frequency accuracy of 30~MHz. We partially resolve the hyperfine structure and measure the nuclear quadrupole coupling of the excited vibrational state.
MTOBGHAL-arXiv.pdf (385.52 Ko) Télécharger le fichier
hal-01348950 , version 1 (29-07-2016)
Sean K. Tokunaga, R. J. Hendricks, M. R. Tarbutt, B Darquié. High-resolution mid-infrared spectroscopy of buffer-gas-cooled methyltrioxorhenium molecules. New Journal of Physics, 2017, 19, pp.053006. ⟨10.1088/1367-2630/aa6de4⟩. ⟨hal-01348950⟩
724 Consultations
127 Téléchargements
