The complexity of $P$4-decomposition of regular graphs and multigraphs
Let G denote a multigraph with edge set E(G), let µ(G) denote the maximum edge multiplicity in G, and let Pk denote the path on k vertices. Heinrich et al.(1999) showed that P4 decomposes a connected 4-regular graph G if and only if |E(G)| is divisible by 3. We show that P4 decomposes a connected 4-regular multigraph G with µ(G) ≤2 if and only if no 3 vertices of G induce more than 4 edges and |E(G)| is divisible by 3. Oksimets (2003) proved that for all integers k ≥3, P4 decomposes a connected 2k-regular graph G if and only if |E(G)| is divisible by 3. We prove that for all integers k ≥2, the problem of determining if P4 decomposes a (2k + 1)-regular graph is NP-Complete. El-Zanati et al.(2014) showed that for all integers k ≥1, every 6k-regular multigraph with µ(G) ≤2k has a P4-decomposition. We show that unless P = NP, this result is best possible with respect to µ(G) by proving that for all integers k ≥3 the problem of determining if P4 decomposes a 2k-regular multigraph with µ(G) ≤⌊2k / 3 ⌋+ 1 is NP-Complete.
Mathématique discrète [cs.DM]
