Polynomial time approximation schemes for dense instances of NP-hard problems, Proceedings of the twenty-seventh annual ACM symposium on Theory of computing, pp.284-293, 1995. ,
Shortest coverings of graphs with cycles, Journal of Combinatorial Theory, Series B, vol.35, issue.3, pp.297-308, 1983. ,
DOI : 10.1016/0095-8956(83)90056-4
Set systems with few disjoint pairs, pp.559-570, 2003. ,
The Lov??sz Number of Random Graphs, Combinatorics, Probability and Computing, vol.14, issue.4, pp.439-465, 2005. ,
DOI : 10.1017/S0963548305006826
High-girth cubic graphs are homomorphic to the Clebsch graph, Journal of Graph Theory, vol.14, issue.6, pp.241-259, 2011. ,
DOI : 10.1002/jgt.20580
On edge-maps whose inverse preserves flows and tensions, Graph Theory in Paris: Proceedings of a Conference in Memory, Trends in Mathematics, 2006. ,
Maximum matching and a polyhedron with 0,1-vertices, Journal of Research of the National Bureau of Standards Section B Mathematics and Mathematical Physics, vol.69, issue.1 and 2, pp.125-130, 1965. ,
DOI : 10.6028/jres.069B.013
An approximability-related parameter on graphs?properties and applications, Discr. Math. Th. Comp. Sc, vol.17, issue.1, pp.33-66, 2015. ,
Graph theory and probability, Canad, J. Math, vol.11, pp.34-38, 1959. ,
Minimum cycle covers of graphs, Journal of Graph Theory, vol.25, issue.3, pp.229-242, 1997. ,
DOI : 10.1002/(SICI)1097-0118(199707)25:3<229::AID-JGT6>3.0.CO;2-N
Graphs with Tiny Vector Chromatic Numbers and Huge Chromatic Numbers, SIAM Journal on Computing, vol.33, issue.6, pp.1338-1368, 2004. ,
DOI : 10.1137/S0097539703431391
URL : http://authors.library.caltech.edu/27189/1/FEIsiamjc04.pdf
Polynomial time approximation of dense weighted instances of MAX-CUT, Random Structures, Algorithms, vol.16, issue.4, pp.314-332, 2000. ,
Approximability distance in the space of Hcolourability problems, Proceedings of the 4th International Computer Science Symposium in Russia, 2009. ,
Robert?ámalRobert?Robert?ámal, and Antonios Varvitsiotis, Rigidity and Graph Theory III: Categorical Products and Unique Homomorphisms, in preparation, 2015. ,
Algebraic graph theory, Graduate Texts in Mathematics, vol.207, 2001. ,
DOI : 10.1007/978-1-4613-0163-9
Improved approximation algorithms for maximum cut and satisfiability problems using semidefinite programming, J. Assoc. Comput. Mach, vol.42, issue.6, pp.1115-1145, 1995. ,
Weakly bipartite graphs and the Max-cut problem, Operations Research Letters, vol.1, issue.1, pp.23-27, 1981. ,
DOI : 10.1016/0167-6377(81)90020-1
Product graphs, structure and recognition, 2000. ,
Random graphs, Wiley-Interscience Series in Discrete Mathematics and Optimization, 2000. ,
Combinatorial Approximation Algorithms for MaxCut using Random Walks, Innovations in Computer Science ? ICS, pp.367-388, 2010. ,
Maximum edge-cuts in cubic graphs with large girth and in random cubic graphs, Random Structures & Algorithms, vol.14, issue.4, pp.506-520, 2012. ,
DOI : 10.1002/rsa.20471
Approximate graph coloring by semidefinite programming, Journal of the ACM, vol.45, issue.2, pp.246-265, 1998. ,
DOI : 10.1145/274787.274791
Coloring 3-colorable graphs with o(n 1/5 ) colors, 31st International Symposium on Theoretical Aspects of Computer Science STACS 2014, pp.458-469, 2014. ,
Kneser's conjecture, chromatic number, and homotopy, Journal of Combinatorial Theory, Series A, vol.25, issue.3, pp.319-324, 1978. ,
DOI : 10.1016/0097-3165(78)90022-5
Combinatorial problems and exercises, 1979. ,
DOI : 10.1090/chel/361
On tension-continuous mappings, European Journal of Combinatorics, vol.29, issue.4, pp.1025-1054, 2008. ,
DOI : 10.1016/j.ejc.2007.11.023
Maximum bipartite subgraphs of Kneser graphs, Graphs Combin, pp.191-199, 1987. ,
A course in combinatorics, 2001. ,
