Improving Vertex Cover as a Graph Parameter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2015
Parameterized algorithms are often used to efficiently solve NP-hard problems on graphs. In this context, vertex cover is used as a powerful parameter for dealing with graph problems which are hard to solve even when parameterized by tree-width; however, the drawback of vertex cover is that bounding it severely restricts admissible graph classes. We introduce a generalization of vertex cover called twin-cover and show that FPT algorithms exist for a wide range of difficult problems when parameterized by twin-cover. The advantage of twin-cover over vertex cover is that it imposes a lesser restriction on the graph structure and attains low values even on dense graphs. Apart from introducing the parameter itself, this article provides a number of new FPT algorithms parameterized by twin-cover with a special emphasis on solving problems which are not in FPT even when parameterized by tree-width. It also shows that MS1 model checking can be done in elementary FPT time parameterized by twin-cover and discusses the field of kernelization.
2378-9773-1-PB.pdf (337.19 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-01349051 , version 1 (26-07-2016)
Robert Ganian. Improving Vertex Cover as a Graph Parameter. Discrete Mathematics and Theoretical Computer Science, 2015, Vol. 17 no.2 (2), pp.77-100. ⟨10.46298/dmtcs.2136⟩. ⟨hal-01349051⟩
Collections
TDS-MACS
70 Consultations
2073 Téléchargements
