On-line handwritten formula recognition using hidden Markov models and context dependent graph grammars - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 1999
This paper presents an approach for the recognition of on-line handwritten mathematical expressions. The Hidden Markov Model (HMM) based system makes use of simultaneous segmentation and recognition capabilities, avoiding a crucial segmentation during pre-processing. With the seg-mentation and recognition results, obtained from the HMM-recognizer, it is possible to analyze and interpret the spatial two-dimensional arrangement of the symbols. We use a graph grammar approach for the structure recognition, also used in off-line recognition process, resulting in a general tree-structure of the underlying input-expression. The resulting constructed tree can be translated to any desired syntax (for example: Lisp, L A T E X, OpenMath. . .).
kosmala-rigoll-etal1999.pdf (72.28 Ko) Télécharger le fichier
hal-01349212 , version 1 (27-07-2016)
Andreas Kosmala, Gerhard Rigoll, Stéphane Lavirotte, Loïc Pottier. On-line handwritten formula recognition using hidden Markov models and context dependent graph grammars. International Conference on Document Analysis and Recognition, Sep 1999, Bangalore, India. 1999, Proceeding of the Fifth International Conference on Document Analysis and Recognition. ⟨10.1109/ICDAR.1999.791736⟩. ⟨hal-01349212⟩
Collections
INRIA INRIA2
101 Consultations
147 Téléchargements
