Embedding native audio-processing in a score following system with quasi sample accuracy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper reports on the experimental native embedding of audio processing into the Antescofo system, to leverage timing precision both at the program and system level, to accommodate time-driven (audio processing) and event-driven (control) computations, and to preserve system behaviour on multiple hardware platforms. Here native embedding means that audio computations can be specified using dedicated DSLs (e.g., Faust) compiled on-the-fly and driven by the Antescofo scheduler. We showcase results through an example of an interactive piece by composer Pierre Boulez, Anthèmes 2 for violin and live electronics.
antescofo_ICMC2016.pdf (974.89 Ko) Télécharger le fichier
hal-01349524 , version 1 (27-07-2016)
  • HAL Id : hal-01349524 , version 1
Pierre Donat-Bouillud, Jean-Louis Giavitto, Arshia Cont, Nicolas Schmidt, Yann Orlarey. Embedding native audio-processing in a score following system with quasi sample accuracy. ICMC 2016 - 42th International Computer Music Conference, Sep 2016, Utrecht, Netherlands. ⟨hal-01349524⟩
277 Consultations
385 Téléchargements
