Voice Activity Detection Based on Statistical Likelihood Ratio With Adaptive Thresholding
Statistical likelihood ratio test is a widely used voice activity detection (VAD) method, in which the likelihood ratio of the current temporal frame is compared with a threshold. A fixed threshold is always used, but this is not suitable for various types of noise. In this paper, an adaptive threshold is proposed as a function of the local statistics of the likelihood ratio. This threshold represents the upper bound of the likelihood ratio for the non-speech frames, whereas it remains generally lower than the likelihood ratio for the speech frames. As a result, a high non-speech hit rate can be achieved, while maintaining speech hit rate as large as possible.
