On Witten Laplacians and Brascamp–Lieb’s Inequality on Manifolds with Boundary - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Integral Equations and Operator Theory Année : 2017
In this paper, we derive from the supersymmetry of the Witten Laplacian Brascamp–Lieb’s type inequalities for general differential forms on compact Riemannian manifolds with boundary. In addition to the supersymmetry, our results essentially follow from suitable decompositions of the quadratic forms associated with the Neumann and Dirichlet self-adjoint realizations of the Witten Laplacian. They moreover imply the usual Brascamp–Lieb’s inequality and its generalization to compact Riemannian manifolds without boundary.
Brascamp-Lieb-Bdy-Arxiv'.pdf (342.46 Ko) Télécharger le fichier
hal-01349786 , version 1 (28-07-2016)
hal-01349786 , version 2 (22-02-2017)
Dorian Le Peutrec. On Witten Laplacians and Brascamp–Lieb’s Inequality on Manifolds with Boundary. Integral Equations and Operator Theory, 2017, 87 (3), pp.411 - 434. ⟨10.1007/s00020-017-2354-1⟩. ⟨hal-01349786v2⟩
370 Consultations
220 Téléchargements
