The CISE Tool: Proving Weakly-Consistent Applications Correct - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alexey Gotsman
  • Fonction : Auteur
  • PersonId : 987061
Hongseok Yang
  • Fonction : Auteur
  • PersonId : 987062
Marc Shapiro
Designers of a replicated database face a vexing choice between strong consistency, which ensures certain application invariants but is slow and fragile, and asynchronous replication, which is highly available and responsive, but exposes the programmer to unfamiliar behaviours. To bypass this conundrum, recent research has studied hybrid consistency models, in which updates are asynchronous by default, but synchronisation is available upon request. To help programmers exploit hybrid consistency, we propose the first static analysis tool for proving integrity invariants of applications using databases with hybrid consistency models. This allows a programmer to find minimal consistency guarantees sufficient for application correctness.
CISE-tool-PaPoC-2016.pdf (187.05 Ko) Télécharger le fichier
hal-01350636 , version 1 (01-08-2016)
Mahsa Najafzadeh, Alexey Gotsman, Hongseok Yang, Carla Ferreira, Marc Shapiro. The CISE Tool: Proving Weakly-Consistent Applications Correct. PaPoC 2016 - 2nd Workshop on the Principles and Practice of Consistency for Distributed Data , Apr 2016, Londres, United Kingdom. ⟨10.1145/2911151.2911160⟩. ⟨hal-01350636⟩
148 Consultations
128 Téléchargements
