Liaison Linkages - Archive ouverte HAL Access content directly
Conference Papers Year :
Liaison Linkages
The complete classification of hexapods - also known as Stewart Gough platforms - of mobility one is still open. To tackle this problem, we can associate to each hexapod of mobility one an algebraic curve, called the configuration curve. In this paper we establish an upper bound for the degree of this curve, assuming the hexapod is general enough. Moreover, we provide a construction of hexapods with curves of maximal degree, which is based on liaison, a technique used in the theory of algebraic curves.
Dates and versions
hal-01350773 , version 1 (01-08-2016)
Identifiers
Cite
Matteo Gallet, Georg Nawratil, Josef Schicho. Liaison Linkages. MEGA'2015 (Special Issue), Jun 2015, Trento, Italy. ⟨hal-01350773⟩
48 View
0 Download
Share
