Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : An executable model plays an important role on verifying the behavior and performance of an architecture. This paper summarizes the state of the art on the synthesis methods of the executable model for an architecture that is compliant with the Department of Defense Architecture Framework (DoDAF). To overcome the deficiencies of current executable modeling studies, a component data-focused method is proposed. Following the introduction of an executable modeling language named OPDL, the data elements of DoDAF Meta-model (DM2) required for building executable model is analyzed. The mapping relations between partial DM2 and OPDL elements are built. Finally, a process to create executable model is explained in detail.
https://hal.inria.fr/hal-01350927 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, August 2, 2016 - 11:26:37 AM Last modification on : Tuesday, September 3, 2019 - 3:04:02 PM Long-term archiving on: : Thursday, November 3, 2016 - 5:21:43 PM
Li Huang, Guangqi Huang, yaohong Zhang, Weizi Li, Xueshan Luo. A Component Data-Focused Method to Build the Executable Model for a DoDAF Compliant Architecture. 15th International Conference on Informatics and Semiotics in Organisations (ICISO), May 2014, Shanghai, China. pp.221-230, ⟨10.1007/978-3-642-55355-4_22⟩. ⟨hal-01350927⟩
