A Logical Pattern for Integrating Business Intelligence into Information Systems Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Stephen Opoku-Anokye
  • Fonction : Auteur
  • PersonId : 987192
Yinshan Tang
  • Fonction : Auteur
  • PersonId : 987191
In this paper, we review, literature concerning the relationship between the requirements for information systems design and business intelligence (BI). This is to provide a basis for discussion on the need for the integration of BI into information systems design. Literature on the current design patterns for information systems and BI were reviewed to identify design trends that are contributing to the use of BI that are based on only the data extracted from source information systems. We observe three main layers of logical design pattern for computer-supported information systems, namely, information presentation layer, domain model layer and information source layer. We classified according to the design purpose of each layer, which are, purposeful use of information presentation (Pragmatics design layer), meaning and understanding of information within particular business domains (Semantics design layer) and storage of signs for information captured and encoded into data (Syntactic design layer). We propose LOPIBIS as a logical pattern for integrating BI into information systems design, which is to support the use of a single version of business rules (SVOBR) to capture, process and recall same sets of data in source information systems. Subsequently enabling to the use of BI that are based on not just the data extracted from source information systems, but data with the contexts of business actions.
978-3-642-55355-4_37_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01350943 , version 1 (02-08-2016)
Paternité
Stephen Opoku-Anokye, Yinshan Tang. A Logical Pattern for Integrating Business Intelligence into Information Systems Design. 15th International Conference on Informatics and Semiotics in Organisations (ICISO), May 2014, Shanghai, China. pp.358-367, ⟨10.1007/978-3-642-55355-4_37⟩. ⟨hal-01350943⟩
173 Consultations
184 Téléchargements
