Research on Control System of Variable Rate Fertilizer Applicator in Precision Farming Based on Combined Positioning of GPS, Electronic Compass and Gyroscope - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
On the Background of precision farming and the precision positioning of variable rate fertilization, the precision farming was achieved and the per unit yield was raised by the integrated positioning method using GPS, electronic compass, and gyroscope.
978-3-642-27281-3_24_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01351810 , version 1 (04-08-2016)
Paternité
Guobing Pan, Xiao Feng. Research on Control System of Variable Rate Fertilizer Applicator in Precision Farming Based on Combined Positioning of GPS, Electronic Compass and Gyroscope. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. pp.188-192, ⟨10.1007/978-3-642-27281-3_24⟩. ⟨hal-01351810⟩
25 Consultations
60 Téléchargements
