X. Li and G. Fan, Influence of organic matter content on infiltration capacity and parameter in field soils, Transactions of the CSAE, vol.22, issue.3, pp.188-190, 2006.
X. Li and G. Fan, Experimental study on main factors influencing the infiltration capacity of unsaturated earth canal, Journal of hydraulic Engineering, vol.40, issue.5, pp.630-634, 2009.
J. Lai, Y. Luo, and L. Ren, Effects of Buffer-Index of the Double-Ring Infiltrometer on Saturated Hydraulic Conductivity Measurements, Acta Pedologica Sinica, pp.19-25, 2010.
G. Fan and Z. Dang, Approach on Infiltration Reducing Mechanism of Infiltration under Surge Irrigation, Bulletin of Soil and Water Conservation, pp.30-33, 1993.
W. Xie and G. Fan, Influence of moisture content on infiltration characteristics in field soils, pp.273-275, 2004.
Q. Wang, J. Horton, and . Fan, An Analytical Solution for One-Dimensional Water Infiltration and Redistribution in Unsaturated Soil, Pedosphere, vol.19, issue.1, pp.104-110, 2009.
DOI : 10.1016/S1002-0160(08)60089-2
T. S. Moroke, O. Dikinya, and C. Patrick, Comparative assessment of water infiltration of soils under different tillage systems in eastern Botswana, Physics and Chemistry of the Earth, Parts A/B/C, vol.34, issue.4-5, pp.316-323, 2009.
DOI : 10.1016/j.pce.2008.08.002
Z. Jianting, P. Binayak, and . Mohanty, Effective scaling factor for transient infiltration in heterogeneous soils
