Equilibrium states and the ergodic theory of Anosov diffeomorphisms. Second revised version, Lect. Notes.in Math, vol.470, issue.1, 2008. ,
Markov chains. Gibbs fields, Monte Carlo simulation, and queues, 1999. ,
On the preservation of Gibbsianness under symbol amalgamation, Entropy of Hidden Markov Processes and Connections to Dynamical Systems, p.81, 2011. ,
DOI : 10.1017/CBO9780511819407.003
Theoretical Neuroscience : Computational and Mathematical Modeling of Neural Systems, 2001. ,
Efficient spike-sorting of multi-state neurons using inter-spike intervals information, Journal of Neuroscience Methods, vol.150, issue.1, pp.16-29, 2006. ,
DOI : 10.1016/j.jneumeth.2005.05.023
URL : https://hal.archives-ouvertes.fr/hal-00005002
The Description of a Random Field by Means of Conditional Probabilities and Conditions of Its Regularity, Theory of Probability & Its Applications, vol.13, issue.2, pp.201-229, 1968. ,
DOI : 10.1137/1113026
Towards reliable spike-train recordings from thousands of neurons with multielectrodes, Current Opinion in Neurobiology, vol.22, issue.1, pp.11-17, 2012. ,
DOI : 10.1016/j.conb.2011.10.001
URL : https://hal.archives-ouvertes.fr/hal-00725382
Mathematical Foundations of Neuroscience, 2010. ,
DOI : 10.1007/978-0-387-87708-2
Chains with complete connections : General theory, uniqueness, loss of memory and mixing properties, J. Stat. Phys, vol.118, pp.3-4555, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-01296844
Global specifications and non-quasilocality of projections of gibbs measures, Ann. Proba, vol.25, issue.3, pp.1284-315, 1997. ,
Regular $g$-measures are not always Gibbsian, Electronic Communications in Probability, vol.16, issue.0, pp.732-740, 2011. ,
DOI : 10.1214/ECP.v16-1681
URL : https://hal.archives-ouvertes.fr/hal-01296794
Large-scale, high-resolution electrophysiological imaging of field potentials in brain slices with microelectronic multielectrode arrays, Frontiers in Neural Circuits, vol.6, issue.80, p.2012 ,
DOI : 10.3389/fncir.2012.00080
On the global Markov property Quantum fields -algebras, processes, Proc. Symp, pp.293-302, 1978. ,
Stochastic chains with memory of variable length, TICSP Series, vol.38, pp.117-133, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00798528
Gibbs Measures and Phase Transitions, De Gruyter Studies in Mathematics, vol.9, 1988. ,
Spiking Neuron Models, 2002. ,
Remarks on the global Markov property, Communications in Mathematical Physics, vol.11, issue.3, pp.223-234, 1980. ,
DOI : 10.1007/BF01952887
Theory of dynamic critical phenomena, Reviews of Modern Physics, vol.49, issue.3, pp.435-479, 1977. ,
DOI : 10.1103/RevModPhys.49.435
Modern theory of critical phenomena, 1976. ,
Mapping a Complete Neural Population in the Retina, Journal of Neuroscience, vol.32, issue.43, pp.14859-14873, 2012. ,
DOI : 10.1523/JNEUROSCI.0723-12.2012
On the criticality of inferred models, Journal of Statistical Mechanics: Theory and Experiment, vol.2011, issue.10, p.10012, 2011. ,
DOI : 10.1088/1742-5468/2011/10/P10012
Predictive information in a sensory population, Proceedings of the National Academy of Sciences, vol.112, issue.22, pp.6908-6913, 2015. ,
DOI : 10.1073/pnas.1506855112
Universal critical amplitudes in finite-size scaling, Physical Review B, vol.30, issue.1, pp.322-327, 1984. ,
DOI : 10.1103/PhysRevB.30.322
Transformations of one-dimensional Gibbs measures with infinite range interaction, Markov Process. Relat. Fields, pp.737-752, 2010. ,
A universal data compression system, IEEE Transactions on Information Theory, vol.29, issue.5, pp.656-664, 1983. ,
DOI : 10.1109/TIT.1983.1056741
Non-negative Matrices and Markov Chains, 2006. ,
DOI : 10.1007/0-387-32792-4
Spin glass models for a network of real neurons, 2009. ,
Decimation of the dyson-ising model, 2016. ,
Regularity properties and pathologies of position-space renormalization-group transformations: Scope and limitations of Gibbsian theory, Journal of Statistical Physics, vol.40, issue.97, pp.5-6879, 1993. ,
DOI : 10.1007/BF01048183
On factors of <mml:math altimg="si1.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>g</mml:mi></mml:math>-measures, Indagationes Mathematicae, vol.22, issue.3-4, pp.315-329, 2011. ,
DOI : 10.1016/j.indag.2011.09.001
The renormalization group: Critical phenomena and the Kondo problem, Reviews of Modern Physics, vol.47, issue.4, pp.773-840, 1975. ,
DOI : 10.1103/RevModPhys.47.773
