ocp-lint, A Plugin-based Style-Checker with Semantic Patches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Çagdas Bozman
Théophane Huffschmitt
  • Fonction : Auteur
  • PersonId : 987371
Michael Laporte
  • Fonction : Auteur
  • PersonId : 987372
In this talk, we will present ocp-lint, a new style-checker for OCaml projects. ocp-lint can typically be used to check pull-requests in a Github-style workflow. ocp-lint is highly ex-tensible, with a simple API to define new plu-gins that can be linked dynamically. ocp-lint is easily configurable, with plugin-and analysis-specific options and arguments. ocp-lint can also use semantic patches, a patch-style format to describe code patterns to detect. Warnings found by ocp-lint are stored in a database, to avoid useless recomputations and ease the development of external tools and GUIs to exploit its results.
ocaml-2016-typerex-lint.pdf (141.14 Ko) Télécharger le fichier
hal-01352013 , version 1 (05-08-2016)
  • HAL Id : hal-01352013 , version 1
Çagdas Bozman, Théophane Huffschmitt, Michael Laporte, Fabrice Le Fessant. ocp-lint, A Plugin-based Style-Checker with Semantic Patches. OCaml Users and Developers Workshop 2016, Sep 2016, Nara, Japan. ⟨hal-01352013⟩
Collections
INRIA INRIA2
128 Consultations
281 Téléchargements
