Analyzing Module Diversity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Universal Computer Science Année : 2005
Each object-oriented programming language proposes various grouping mechanisms to bundle interacting classes (i.e., packages, modules, selector namespaces, etc). To understand this diversity and to compare the different approaches, a common foundation is needed. In this paper we present a simple module calculus consisting of a small set of operators over environments and modules. Using these operators, we are then able to specify a set of module combinators that capture the semantics of Java packages, C# namespaces, Ruby modules, selector namespaces, gbeta classes, classboxes, MZScheme units, and MixJuice modules. We develop a simple taxonomy of module systems, and show how particular combinations of module operators help us to draw sharp distinctions between classes of module systems that share similar characteristics.
jucs_11_10_1613_1644_bergel.pdf (357.24 Ko) Télécharger le fichier
hal-01352809 , version 1 (09-08-2016)
Alexandre Bergel, Stéphane Ducasse, Oscar Nierstrasz. Analyzing Module Diversity. Journal of Universal Computer Science, 2005, 11 (10), pp.32. ⟨10.3217/jucs-011-10-1613⟩. ⟨hal-01352809⟩
107 Consultations
84 Téléchargements
