Distance-Regular Graphs, 1989. ,
Width and dual width of subsets in polynomial association schemes, Journal of Combinatorial Theory, Series A, vol.102, issue.2, pp.255-271, 2003. ,
DOI : 10.1016/S0097-3165(03)00006-2
Algebraic Combinatorics I: Association Schemes, 1984. ,
A family of nonbinary linear codes, Discrete Math, vol.65, issue.1, pp.41-51, 1987. ,
A note on completely regular codes, Discrete Math, vol.83, issue.1, pp.115-117, 1990. ,
On $q$-ary linear completely regular codes with $\rho=2$ and antipodal dual, Advances in Mathematics of Communications, vol.4, issue.4, pp.567-578, 2010. ,
DOI : 10.3934/amc.2010.4.567
An algebraic approach to the association schemes of coding theory, Philips Res. Rep, issue.10, p.97, 1973. ,
Q-polynomial structures for association schemes and distance-regular graphs. thesis, 1995. ,
Distance-regular graphs. preprint, 2014. arXiv:1410.6294. [Ega81] Y. Egawa. Characterization of H(n, q) by the parameters, J. Combin. Theory Ser. A, issue.2, pp.31108-125, 1981. ,
Algebraic Combinatorics, 1993. ,
Characterizing completely regular codes from an algebraic viewpoint, Contemp. Math, vol.531, pp.223-242, 2010. ,
DOI : 10.1090/conm/531/10470
Tight 2-designs and perfect 1-codes in Doob graphs, Journal of Statistical Planning and Inference, vol.86, issue.2, pp.505-513, 2000. ,
DOI : 10.1016/S0378-3758(99)00126-3
Orthogonal polynomials, duality, and association schemes, SIAM J. Math. Anal, vol.13, issue.4, pp.656-663, 1982. ,
Completely regular designs of strength one Minimum distance bounds for s-regular codes, J. Algebraic Combin. Des. Codes Cryptogr, vol.3, issue.21, pp.177-1851, 1994. ,
Completely regular codes. Discrete Math, pp.353-360, 1992. ,
Completely regular codes with different parameters and the same distanceregular coset graphs. preprint, 2015. ,
Vertex subsets with minimal width and dual width in Q-polynomial distance-regular graphs, Electron. J. Combin, vol.18, issue.1, p.167, 2011. ,
The classification of distance-regular graphs of type IIB, Combinatorica, vol.8, issue.1, pp.125-132, 1988. ,
The subconstituent algebra of an association scheme I, J. Algebraic Combin, vol.1, issue.4, pp.363-388, 1992. ,
