Graph Theory with Applications, 1976. ,
DOI : 10.1007/978-1-349-03521-2
A Characterization of the degree sequences of 2-trees, Journal of Graph Theory, vol.34, issue.2, pp.191-209, 2008. ,
DOI : 10.1002/jgt.20302
On spanning 2-trees in a graph, Discrete Applied Mathematics, vol.74, issue.3, pp.203-216, 1997. ,
DOI : 10.1016/S0166-218X(96)00045-5
Graphs with prescribed degrees of vertices (Hungarian), pp.264-274, 1960. ,
Graphs realizing the same degree sequences and their respective clique numbers Graph Theory, Combinatorics and Applications, pp.439-449, 1991. ,
Potentially G-graphical degree sequences Combinatorics, Graph Theory, and Algorithms, pp.451-460, 1999. ,
Algorithms for constructing graphs and digraphs with given valences and factors, Discrete Mathematics, vol.6, issue.1, pp.79-88, 1973. ,
DOI : 10.1016/0012-365X(73)90037-X
A note on potentially K4 ? e graphical sequences, Australas. J. Combin, vol.24, pp.123-127, 2001. ,
On the potentially Pk-graphic sequences, Discrete Mathematics, vol.195, issue.1-3, pp.255-262, 1999. ,
DOI : 10.1016/S0012-365X(98)00182-4
Two sufficient conditions for a graphic sequence to have a realization with prescribed clique size, Discrete Mathematics, vol.301, issue.2-3, pp.218-227, 2005. ,
DOI : 10.1016/j.disc.2005.03.028
An extremal problem on potentially Kr,s-graphic sequences, Discrete Mathematics, vol.260, issue.1-3, pp.295-305, 2003. ,
DOI : 10.1016/S0012-365X(02)00765-3
A variation of a conjecture due to Erd??s and S??s, Acta Mathematica Sinica, English Series, vol.195, issue.5, pp.795-802, 2009. ,
DOI : 10.1007/s10114-009-7260-2
An extremal problem on potentially Kr,s-graphic sequences, Discrete Mathematics, vol.260, issue.1-3, pp.151-159, 2005. ,
