New interface
Reports (Technical report)
PigReuse: A Reuse-based Optimizer for Pig Latin
Abstract : Pig Latin is a popular language which is widely used for parallel processing of massive data sets. Currently, subexpressions occurring repeatedly in Pig Latin scripts are executed as many times as they appear, and the current Pig Latin optimizer does not identify reuse opportunities. We present a novel optimization approach aiming at identifying and reusing repeated subexpressions in Pig Latin scripts. Our optimization algorithm, named PigReuse, operates on a particular algebraic representation of Pig Latin scripts. PigReuse identifies subexpression merging opportunities, selects the best ones to execute based on a cost function, and reuses their results as needed in order to compute exactly the same output as the original scripts. Our experiments demonstrate the effectiveness of our approach.
Document type :
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/hal-01353891
Contributor : Jesús Camacho-Rodríguez Connect in order to contact the contributor
Submitted on : Thursday, August 18, 2016 - 1:24:47 PM
Last modification on : Friday, November 18, 2022 - 9:28:38 AM
Long-term archiving on: : Saturday, November 19, 2016 - 8:31:18 PM
File
pigreuse-technical-report.pdf
Identifiers
  • HAL Id : hal-01353891, version 1
Citation
Jesús Camacho-Rodríguez, Dario Colazzo, Melanie Herschel, Ioana Manolescu, Soudip Roy Chowdhury. PigReuse: A Reuse-based Optimizer for Pig Latin. [Technical Report] Inria Saclay. 2016. ⟨hal-01353891⟩
Share
Metrics
Record views
371
Files downloads
332
