Analyzing Dynamic Task-Based Applications on Hybrid Platforms: An Agile Scripting Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present visual analysis techniques to evaluate the performance of HPC task-based applications on hybrid architectures. Our approach is based on composing modern data analysis tools (pjdump, R, ggplot2, plotly), enabling an agile and flexible scripting framework with minor development cost. We validate our proposal by analyzing traces from the full-fledged implementation of the Cholesky decomposition available in the MORSE library running on a hybrid (CPU/GPU) platform. The analysis compares two different workloads and three different task schedulers from the StarPU runtime system. Our analysis based on composite views allows to identify allocation mistakes, priority problems in scheduling decisions, GPU tasks anomalies causing bad performance, and critical path issues.
VPA_2016_paper_3.pdf (2.74 Mo) Télécharger le fichier
hal-01353962 , version 1 (16-08-2016)
hal-01353962 , version 2 (17-07-2018)
  • HAL Id : hal-01353962 , version 1
Vinicius Garcia Pinto, Luka Stanisic, Arnaud Legrand, Lucas Mello Schnorr, Samuel Thibault, et al.. Analyzing Dynamic Task-Based Applications on Hybrid Platforms: An Agile Scripting Approach. 3rd Workshop on Visual Performance Analysis (VPA), Nov 2016, Salt Lake City, United States. ⟨hal-01353962v1⟩
849 Consultations
635 Téléchargements
