Numerical Evaluation of Line Integrals, SIAM Journal on Numerical Analysis, vol.30, issue.3, pp.882-888, 1993. ,
DOI : 10.1137/0730046
An inverse problem originating from magnetohydrodynamics . III. Domains with corners of arbitrary angles, Asymptotic Anal, vol.11, issue.3, pp.289-315, 1995. ,
Numerical simulation and optimal control in plasma physics ,
Finite Elements: Theory, fast solvers and applications in solid mechanics, 2nd edn, Measurement Science and Technology, vol.13, issue.9, 2007. ,
DOI : 10.1088/0957-0233/13/9/704
Basic error estimates for elliptic problems In Handbook of numerical analysis, Handb. Numer. Anal., II, vol.II, pp.17-351, 1991. ,
Computing with hp-adaptive finite elements One and two dimensional elliptic and Maxwell problems, CRC Applied Mathematics and Nonlinear Science Series. Chapman & Hall/CRC, vol.1, p.1, 2007. ,
Discretization of Dirac delta functions in level set methods, Journal of Computational Physics, vol.207, issue.1, pp.28-51, 2005. ,
DOI : 10.1016/j.jcp.2004.09.018
Geometric measure theory. Die Grundlehren der mathematischen Wissenschaften, 1969. ,
Concepts ? An Object-Oriented Software Package for Partial Differential Equations, ESAIM: Math. Model. Numer. Anal, vol.36, issue.5, pp.937-951, 2002. ,
Higher-order accurate integration of implicit geometries, International Journal for Numerical Methods in Engineering, vol.21, issue.3, pp.323-371 ,
DOI : 10.1002/nme.5121
Principles of magnetohydrodynamics: with applications to laboratory and astrophysical plasmas, 2004. ,
DOI : 10.1017/CBO9780511616945
Classical Diffusion in a Tokomak, Physical Review Letters, vol.24, issue.24, pp.1337-1340, 1970. ,
DOI : 10.1103/PhysRevLett.24.1337
Hydromagnetic equilibria and force-free fields, Proceedings of the 2nd UN Conf. on the Peaceful Uses of Atomic Energy, p.190, 1958. ,
DOI : 10.1016/0891-3919(58)90139-6
Quasi-static free-boundary equilibrium of toroidal plasma with CEDRES++: Computational methods and applications, Journal of Plasma Physics, vol.6, issue.03, p.2015 ,
DOI : 10.1016/j.fusengdes.2011.03.092
URL : https://hal.archives-ouvertes.fr/hal-01088772
Theory of plasma transport in toroidal confinement systems, Reviews of Modern Physics, vol.48, issue.2, pp.239-308, 1976. ,
DOI : 10.1103/RevModPhys.48.239
Computational methods in plasma physics, 2010. ,
DOI : 10.1201/EBK1439810958
Numerical methods for elliptic and parabolic partial differential equations, Texts in Applied Mathematics, vol.44, 2003. ,
ECOM: A fast and accurate solver for toroidal axisymmetric MHD equilibria, Computer Physics Communications, vol.190, issue.0, pp.72-88, 2015. ,
DOI : 10.1016/j.cpc.2015.01.015
Marching cubes: A high resolution 3D surface construction algorithm, ACM SIGGRAPH Computer Graphics, vol.21, issue.4, pp.163-169, 1987. ,
DOI : 10.1145/37402.37422
Axialsymmetrische magnetohydrodynamische Gleichgewichtskonfigurationen, Zeitschrift f??r Naturforschung A, vol.12, issue.10, pp.850-854, 1957. ,
DOI : 10.1515/zna-1957-1014
The CHEASE code for toroidal MHD equilibria, Computer Physics Communications, vol.97, issue.3, pp.219-260, 1996. ,
DOI : 10.1016/0010-4655(96)00046-X
Geometric integration over irregular domains with application to level-set methods, Journal of Computational Physics, vol.226, issue.2, pp.1432-1443, 2007. ,
DOI : 10.1016/j.jcp.2007.05.032
A survey of the marching cubes algorithm, Computers & Graphics, vol.30, issue.5, pp.854-879, 2006. ,
DOI : 10.1016/j.cag.2006.07.021
Surface mapping brain function on 3D models, IEEE Computer Graphics and Applications, vol.10, issue.5, pp.33-41, 1990. ,
DOI : 10.1109/38.59034
Computation of the band structure of two-dimensional photonic crystals with hp finite elements, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.13-14, pp.1249-1259, 2009. ,
DOI : 10.1016/j.cma.2008.06.009
URL : https://hal.archives-ouvertes.fr/hal-00974812
p-and hp-finite element methods : theory and applications in solid and fluid mechanics, 2004. ,
On magnetohydrodynamical equilibrium configurations, Soviet Journal of Experimental and Theoretical Physics, vol.6, p.545, 1958. ,
A polygonal approximation to direct scalar volume rendering, ACM SIGGRAPH Computer Graphics, vol.24, issue.5, pp.63-70, 1990. ,
DOI : 10.1145/99308.99322
The averaged Green function with applications to quasi-static plasma equilibrium, 1977. ,
The queer differential equations for adiabatic compression of plasma, Bulletin of the American Mathematical Society, vol.1, issue.5, pp.778-781, 1979. ,
DOI : 10.1090/S0273-0979-1979-14664-0
Local behavior in finite element methods In Finite Element Methods (Part 1), volume 2 of Handbook of Numerical Analysis, pp.353-522, 1991. ,
On highorder FEM applied to canonical scattering problems in plasmonics, J. Comput. Theor. Nanosci, vol.8, pp.1-9, 2011. ,
