Conference papers
A different re-execution speed can help
Abstract : We consider divisible load scientific applications executing on large-scale platforms subject to silent errors. While the goal is usually to complete the execution as fast as possible in expectation, another major concern is energy consumption. The use of dynamic voltage and frequency scaling (DVFS) can help save energy, but at the price of performance degradation. Consider the execution model where a set of K different speeds is given, and whenever a failure occurs, a different re-execution speed may be used. Can this help? We address the following bi-criteria problem: how to compute the optimal checkpointing period to minimize energy consumption while bounding the degradation in performance. We solve this bi-criteria problem by providing a closed-form solution for the checkpointing period, and demonstrate via a comprehensive set of simulations that a different re-execution speed can indeed help.
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-01354887
Contributor : Equipe Roma Connect in order to contact the contributor
Submitted on : Friday, August 19, 2016 - 7:03:59 PM
Last modification on : Friday, September 30, 2022 - 4:12:13 AM
Long-term archiving on: : Sunday, November 20, 2016 - 10:40:25 AM
File
pasa2016.pdf
Identifiers
  • HAL Id : hal-01354887, version 1
Collections
Citation
Anne Benoit, Aurélien Cavelan, Valentin Le Fèvre, Yves Robert, Hongyang Sun. A different re-execution speed can help. 5th International Workshop on Power-aware Algorithms, Systems, and Architectures (PASA'16), held in conjunction with ICPP 2016, the 45th International Conference on Parallel Processing, Aug 2016, Philadelphia, United States. ⟨hal-01354887⟩
Share
Metrics
Record views
194
Files downloads
62
