Hydrodynamic singular regimes in 1+1 kinetic models and spectral numerical methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Analysis and Applications Année : 2016
Classical results from spectral theory of stationary linear kinetic equations are applied to efficiently approximate two physically relevant weakly nonlinear kinetic models: a model of chemotaxis involving a biased velocity-redistribution integral term, and a Vlasov-Fokker-Planck (VFP) system. Both are coupled to an attractive elliptic equation producing corresponding mean-field potentials. Spectral de-compositions of stationary kinetic distributions are recalled, based on a variation of Case's elementary solutions (for the first model) and on a Sturm-Liouville eigenvalue problem (for the second one). Well-balanced Godunov schemes with strong stability properties are deduced. Moreover, in the stiff hydrodynamical scaling, an hybridized algorithm is set up, for which asymptotic-preserving properties can be established under mild restrictions on the computational grid. Several numerical validations are displayed, including the consistency of the VFP model with Burgers-Hopf dynamics on the velocity field after blowup of the macroscopic density into Dirac masses.
hybrid_v4.pdf (120.32 Ko) Télécharger le fichier
hal-01354980 , version 1 (22-08-2016)
Laurent Gosse, Nicolas Vauchelet. Hydrodynamic singular regimes in 1+1 kinetic models and spectral numerical methods. Journal of Mathematical Analysis and Applications, 2016, ⟨10.1016/j.jmaa.2016.07.059⟩. ⟨hal-01354980⟩
292 Consultations
119 Téléchargements
