Subduction controls the distribution and fragmentation of Earth’s tectonic plates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nature Année : 2016
The theory of plate tectonics describes how the surface of the Earth is split into an organized jigsaw of seven large plates 1 of similar sizes and a population of smaller plates, whose areas follow a fractal distribution 2,3. The reconstruction of global tectonics during the past 200 My 4 suggests that this layout is probably a long-term feature of our planet, but the forces governing it are unknown. Previous studies 3,5,6 , primarily based on statistical properties of plate distributions, were unable to resolve how the size of plates is determined by lithosphere properties and/or underlying mantle convection. Here, we demonstrate that the plate layout of the Earth is produced by a dynamic feedback between mantle convection and the strength of the lithosphere. Using 3D spherical models of mantle convection with plate-like behaviour that match the plate size-frequency distribution observed for Earth, we show that subduction geometry drives the tectonic fragmentation that generates plates. The spacing between slabs controls the layout of large plates, and the stresses caused by the bending of trenches, break plates into smaller fragments. Our results explain why the fast evolution in small back-arc plates 7,8 reflects the dramatic changes in plate motions during times of major reorganizations. Our study opens the way to use convection simulations with plate-like behaviour to unravel how global tectonics and mantle convection are dynamically connected.
Mallard2016_augury.pdf (4.76 Mo) Télécharger le fichier
hal-01355818 , version 1 (24-08-2016)
Claire Mallard, Nicolas Coltice, Maria Seton, R.D. Müller, Paul J. Tackley. Subduction controls the distribution and fragmentation of Earth’s tectonic plates. Nature, 2016, 535 (7610), pp.140-143. ⟨10.1038/nature17992⟩. ⟨hal-01355818⟩
195 Consultations
1397 Téléchargements
