Facing Computing as Technique: Towards a history and philosophy of computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Knowledge, Technology and Policy Année : 2016
This paper introduces the journal special issue on Trends in the History and Philosophy of Computing which was the result of the first conference on the History and Philosophy of Computing. It states and explains the ambitions and motivations of the HaPoC conference series and commission.
facing_PT.pdf (84.14 Ko) Télécharger le fichier
hal-01356336 , version 1 (25-08-2016)
Liesbeth de Mol, Giuseppe Primiero. Facing Computing as Technique: Towards a history and philosophy of computing. Knowledge, Technology and Policy, 2016, 27 (3), pp.321-326. ⟨10.1007/s13347-014-0169-4⟩. ⟨hal-01356336⟩
198 Consultations
152 Téléchargements
