Interval Observers for Linear Impulsive Systems
The problem of interval observer design is studied for a class of linear hybrid systems. Several observers are designed oriented on different conditions of positivity and stability for estimation error dynamics. Efficiency of the proposed approach is demonstrated by computer experiments for academic and bouncing ball systems.
