System identification of microwave filters from multiplexers by rational interpolation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2016
Microwave multiplexers are multi-port structures composed of several two-port filters connected to a common junction. This paper addresses the de-embedding problem, in which the goal is to determine the filtering components given the measured scattering parameters of the overall multiplexer at several frequencies. Due to structural properties, the transmission zeros of the filters play a crucial role in this problem, and, consequently, in our approach. We propose a system identification algorithm for deriving a rational model of the filters' scattering matrix. The approach is based on rational interpolation with derivative constraints, with the interpolation conditions being located precisely at the filters' transmission zeros.
Lefteriu_automatica_paper_final_submission.pdf (653.5 Ko) Télécharger le fichier
hal-01357934 , version 1 (30-08-2016)
  • HAL Id : hal-01357934 , version 1
Sanda Lefteriu, Martine Olivi, Fabien Seyfert, Matteo Oldoni. System identification of microwave filters from multiplexers by rational interpolation. Automatica, 2016. ⟨hal-01357934⟩
272 Consultations
305 Téléchargements
