Improved Vascular Transport Function Characterization in DSC-MRI via Deconvolution with Dispersion-Compliant Bases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bolus dispersion affects the residue function computed via deconvolution of DSC-MRI data. The obtained effective residue function can be expressed as the convolution of the true one with a Vascular Transport Function (VTF) that characterizes dispersion. The state-of-the-art technique CPI+VTF allows to estimate the actual residue function by assuming a model of VTF. We propose to perform deconvolution representing the effective residue function with Dispersion-Compliant Bases (DCB) with no assumptions on the VTF, and then apply the CPI+VTF on DCB results, to improve performance.
Poster_Pizzolato_ISMRM_2016.pdf (778.84 Ko) Télécharger le fichier
Pizzolato_et_al_improved_VTF_ISMRM_2016.pdf (971.94 Ko) Télécharger le fichier
hal-01358775 , version 1 (01-09-2016)
Paternité - Pas d'utilisation commerciale - Pas de modification
  • HAL Id : hal-01358775 , version 1
Marco Pizzolato, Rutger H.J. Fick, Timothé Boutelier, Rachid Deriche. Improved Vascular Transport Function Characterization in DSC-MRI via Deconvolution with Dispersion-Compliant Bases. ISMRM 2016, May 2016, Singapore, Singapore. ⟨hal-01358775⟩
188 Consultations
190 Téléchargements
