Surrogate Assisted Feature Computation for Continuous Problems
Nacim Belkhir 1, 2 Johann Dréo 1 Pierre Savéant 1 Marc Schoenauer 3, 2, *
* Auteur correspondant
2 TAO - Machine Learning and Optimisation
CNRS - Centre National de la Recherche Scientifique : UMR8623, Inria Saclay - Ile de France, UP11 - Université Paris-Sud - Paris 11, LRI - Laboratoire de Recherche en Informatique
Abstract : A possible approach to Algorithm Selection and Configuration for continuous black box optimization problems relies on problem features, computed from a set of evaluated sample points. However, the computation of the features proposed in the literature require a rather large number of such sample points, unlikely to be practical for expensive real-world problems. On the other hand, surrogate models have been proposed to tackle the optimization of expensive objective function. It is proposed in this paper to use surrogate models to approximate the values of the features at reasonable computational cost. Two experimental studies are conducted, using the well-known BBOB framework as testbench. First, the effect of sub-sampling is analyzed. Then, a methodology to compute approximate values for the features using a surrogate model is proposed, and validated from the point of view of retrieving BBOB classes. It is shown that when only small computational budgets are available, using surrogate models as proxies to compute the features can be beneficial.
Type de document :
Communication dans un congrès
Paola Festa. LION 10 Learning and Intelligent OptimizatioN Conference, May 2016, Ischia, Italy. Springer Verlag, To appear, Proc. Learning and Intelligent OptimizatioN Conference
Liste complète des métadonnées
Littérature citée [13 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01303320
Contributeur : Nacim Belkhir <>
Soumis le : vendredi 2 septembre 2016 - 15:41:56
Dernière modification le : jeudi 5 avril 2018 - 12:30:12
Document(s) archivé(s) le : dimanche 4 décembre 2016 - 23:57:36
Fichier
LION_10_paper_31.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-01303320, version 2
Citation
Nacim Belkhir, Johann Dréo, Pierre Savéant, Marc Schoenauer. Surrogate Assisted Feature Computation for Continuous Problems. Paola Festa. LION 10 Learning and Intelligent OptimizatioN Conference, May 2016, Ischia, Italy. Springer Verlag, To appear, Proc. Learning and Intelligent OptimizatioN Conference. 〈hal-01303320v2〉
Métriques
Consultations de la notice
1254
Téléchargements de fichiers
108
