Surface reconstruction by Voronoi filtering, Proc. ACM SCG, pp.39-48, 1998. ,
A new Voronoibased surface reconstruction algorithm, pp.415-421, 1998. ,
The power crust, Proc. ACM SMA, pp.249-266, 2001. ,
Computing and simplifying 2D and 3D continuous skeletons, pp.261-273, 1997. ,
The ball-pivoting algorithm for surface reconstruction, IEEE TVCG, vol.5, issue.3, pp.349-359, 1999. ,
Exact computation of the medial axis of a polyhedron, pp.65-98, 2004. ,
The ?-medial axis, Graph. Models, vol.67, issue.4 2, 2005. ,
Surface reconstruction from point clouds by transforming the medial scaffold, CVIU, vol.113, issue.1 3, pp.1130-1146, 2009. ,
Isotopic reconstruction of surfaces with boundaries, pp.1371-1382, 2009. ,
Incremental topological flipping works for regular triangulations, Proc. ACM SCG, 1992. ,
A formal classification of 3D medial axis points and their local geometry Bounded biharmonic weights for real-time deformation, IEEE TPAMI ACM TOG, vol.1, issue.78, pp.238-2511, 2004. ,
Surface and curve skeletonization of large 3D models on the GPU, IEEE TPAMI, vol.35, issue.6 2 3 5, pp.1495-1508, 2013. ,
B-mesh: A modeling system for base meshes of 3D articulated shapes, pp.2169-2178, 2010. ,
An unified multiscale framework for planar, surface, and curve skeletonization, IEEE TPAMI, vol.38, issue.1 1, pp.30-45, 2016. ,
Computing curve skeletons from medial surfaces of 3D shapes, Proc. Theory & Practice of Computer Graphics (TPCG) (2012), Eurographics, pp.99-106 ,
Robust segmentation of multiple intersecting manifolds from unoriented noisy point clouds, pp.73-87, 2014. ,
Computing refined skeletal features from medial point clouds, Patt Recog Lett, vol.76, pp.13-21, 2015. ,
The shock scaffold for representing 3D shape, Visual Form, pp.216-227, 2001. ,
The medial scaffold of 3D unorganized point clouds, IEEE TVCG, vol.29, issue.2 5, pp.313-330, 2007. ,
3D medial axis point approximation using nearest neighbors and the normal field, Visual Comput, vol.28, issue.1 2 3 5, pp.7-19, 2012. ,
Tensor voting: a perceptual organization approach to computer vision and machine learning, 2007. ,
Delaunay Triangulation in R 3 on the GPU ,
Comparison of curve and surface skeletonization methods for voxel shapes, Pattern Recogn. Lett, vol.47, issue.2 5, pp.147-156, 2014. ,
Skeleton based shape matching and retrieval, Proc. SMI, pp.130-137, 2003. ,
Qualitative comparison of contraction-based curve skeletonization methods, Proc. ISMM, pp.425-439, 2013. ,
3D Skeletons: A State-of-the-Art Report, Computer Graphics Forum, vol.29, issue.2, pp.573-597, 2016. ,
DOI : 10.1111/cgf.12865
URL : https://hal.archives-ouvertes.fr/hal-01300281
