Soil and Agriculture in the Loess Plateau, 1989. ,
Water Use and Soil Water Depletion by Dryland Winter Wheat as Affected by Nitrogen Fertilization1, Agronomy Journal, vol.63, issue.1, pp.43-46, 1971. ,
DOI : 10.2134/agronj1971.00021962006300010015x
FACTORS AFFECTING FERTILIZER RESPONSE OF WHEAT IN SOUTHWESTERN SASKATCHEWAN, Canadian Journal of Soil Science, vol.62, issue.4, pp.577-586, 1982. ,
DOI : 10.4141/cjss82-065
Soil and plant factors affecting evaporation Irrigation of Agricultural Crops, Agronomic Monograph 30, pp.363-390, 1990. ,
Effect of increased fertilizer applications to wheat crop on soil-water depletion in the Loess Plateau, China, Agricultural Water Management, vol.58, issue.3, pp.267-278, 2003. ,
DOI : 10.1016/S0378-3774(02)00086-0
Fluctuation of yield on high-yield field and desiccation of the soil on dryland, Chin. J. Acta Pedol. Sin, vol.38, issue.3, pp.353-355, 2001. ,
WAVES?An Integrated Energy and Water Balance Model, CSIRO Land and Water Technical Report no, Australia, vol.98, issue.31, 1998. ,
A Numerical Model for Water and Solute Movement in and Below the Root Zone, Research Report, issue.121, 1987. ,
The DSSAT cropping system model, European Journal of Agronomy, vol.18, issue.3-4, pp.235-265, 2003. ,
DOI : 10.1016/S1161-0301(02)00107-7
A Modeling Approach to Determining the Relationship Between Erosion and Soil Productivity, Transactions of the ASAE, vol.27, issue.1, pp.129-144, 1984. ,
DOI : 10.13031/2013.32748
Evaluation of crop yield and soil water estimates using the EPIC model for the Loess Plateau of China, Mathematical and Computer Modelling, vol.51, issue.11-12, pp.1390-1397, 2010. ,
DOI : 10.1016/j.mcm.2009.10.030
An assessment of the core-break method for estimating root density of different crops in the field, Soil Tillage Res, vol.9, issue.24, pp.343-347, 1987. ,
Methods of Soil Analysis. Part I. Physical and Mineralogical Methods, pp.363-382, 1986. ,
The EPIC Crop Growth Model, Transactions of the ASAE, vol.32, issue.2, pp.497-511, 1989. ,
DOI : 10.13031/2013.31032
The EPIC model Computer Models of Watershed Hydrology, Water Resources Publications, Highlands Ranch, CO, 1995. ,
Sensitivity of crop yield and water use to change in a range of climatic factors and CO, concentrations: a simulation study applying EPIC to the central USA, Agr. Forest. Meteorol, vol.83, pp.17-203, 1997. ,
Reliability and input-data induced uncertainty of the EPIC model to estimate climate change impact on sorghum yields in the U.S. Great Plains, Agriculture, Ecosystems & Environment, vol.129, issue.1-3, pp.268-276, 2009. ,
DOI : 10.1016/j.agee.2008.09.012
Simulating soil C dynamics with EPIC: Model description and testing against long-term data, Ecological Modelling, vol.192, issue.3-4, pp.362-384, 2006. ,
DOI : 10.1016/j.ecolmodel.2005.07.010
The EPIC Model EPIC?Erosion Productivity Impact Calculator. 1. Model Documentation, pp.3-86, 1990. ,
Using EPIC model to manage irrigated cotton and maize, Agricultural Water Management, vol.96, issue.9, pp.1323-1331, 2009. ,
DOI : 10.1016/j.agwat.2009.03.021
Effect of irrigation and nitrogen on water use efficiency of wheat in Saudi Arabia, Agricultural Water Management, vol.27, issue.2, pp.143-153, 1995. ,
DOI : 10.1016/0378-3774(95)91233-W
SPSS for Windows Base System User's Guide Release 6.0, Marija J. Norusis/SPSS Inc, 1977. ,
Nitrogen Fertility Influence on Water Stress and Yield of Winter Wheat, Agronomy Journal, vol.83, issue.6 ,
DOI : 10.2134/agronj1991.00021962008300060025x
Water restoration of dry soil layers in the Loess Plateau and crop yield response, Res. Soil Water Conserv, vol.14, issue.3, pp.1-4, 2007. ,
Simulation of yield and soil desiccation effects of continuous spring maize in different precipitation areas of the Loess Plateau, Acta Ecol. Sin, vol.29, issue.4, pp.2053-2066, 2009. ,
Overview of Long-Term Agronomic Research, Agronomy Journal, vol.83, issue.1 ,
DOI : 10.2134/agronj1991.00021962008300010010x
Significance of Ancient Agricultural Soils for Long-Term Agronomic Studies and Sustainable Agriculture Research, Agronomy Journal, vol.83, issue.1, pp.29-37, 1991. ,
DOI : 10.2134/agronj1991.00021962008300010011x
Sustainable recovery of soil desiccation in semi-humid region on the Loess Plateau, Agricultural Water Management, vol.98, issue.8, pp.1262-1270, 2011. ,
DOI : 10.1016/j.agwat.2011.03.007
