Monitoring spring canopy phenology of a deciduous broadleaf forest using MODIS, Remote Sensing of Environment, vol.104, issue.1, pp.88-95, 2006. ,
DOI : 10.1016/j.rse.2006.05.003
Responses of spring phenology to climate change, New Phytologist, vol.9, issue.2, pp.295-309, 2004. ,
DOI : 10.1029/2000JD000115
Improved monitoring of vegetation dynamics at very high latitudes: A new method using MODIS NDVI, Remote Sensing of Environment, vol.100, issue.3, pp.321-334, 2006. ,
DOI : 10.1016/j.rse.2005.10.021
A ground???validated NDVI dataset for monitoring vegetation dynamics and mapping phenology in Fennoscandia and the Kola peninsula, International Journal of Remote Sensing, vol.108, issue.19, pp.28-4311, 2007. ,
A curve fitting procedure to derive inter-annual phenologies from time series of noisy satellite NDVI data, Remote Sensing of Environment, vol.106, issue.2, pp.137-145, 2007. ,
DOI : 10.1016/j.rse.2006.08.002
A simple method for reconstructing a high-quality NDVI time-series data set based on the Savitzky -Golay filter, pp.3-4, 2004. ,
Monitoring wheat phenology and irrigation in Central Morocco: On the use of relationships between evapotranspiration, crops coefficients, leaf area index and remotely-sensed vegetation indices, Agricultural Water Management, vol.79, issue.1, pp.1-27, 2006. ,
DOI : 10.1016/j.agwat.2005.02.013
Green leaf phenology at Landsat resolution: Scaling from the field to the satellite, Remote Sensing of Environment, vol.100, issue.2, pp.265-279, 2006. ,
DOI : 10.1016/j.rse.2005.10.022
Modeling temporal changes in surface spatial heterogeneity over an agricultural site, Remote Sensing of Environment, vol.112, issue.2, pp.588-602, 2008. ,
DOI : 10.1016/j.rse.2007.05.014
Classifying rangeland vegetation type and coverage from NDVI time series using Fourier Filtered Cycle Similarity, International Journal of Remote Sensing, vol.10, issue.24, pp.5535-5554, 2005. ,
DOI : 10.1080/01431169408954355
Noise reduction of NDVI time series: An empirical comparison of selected techniques Remote Sensing of Environment, pp.248-258, 2009. ,
Characteristics of maximum-value composite images from temporal AVHRR data, International Journal of Remote Sensing, vol.7, issue.11, pp.1417-1434, 1986. ,
DOI : 10.1016/0034-4257(83)90053-6
Assessment of Potato Phenological Characteristics Using MODIS-Derived NDVI and LAI Information, GIScience & Remote Sensing, vol.45, issue.4, pp.454-470, 2008. ,
DOI : 10.2747/1548-1603.45.4.454
Seasonality extraction by function fitting to time-series of satellite sensor data, IEEE Transactions on Geoscience and Remote Sensing, vol.40, issue.8, pp.40-1824, 2002. ,
DOI : 10.1109/TGRS.2002.802519
TIMESAT-A program for analyzing time-series of satellite sensor data, Computers and Geosciences, pp.833-845, 2004. ,
Analysis of the phenology of global vegetation using meteorological satellite data, International Journal of Remote Sensing, vol.3, issue.8, pp.1271-1318, 1985. ,
DOI : 10.1080/01431168508948281
Removal of Noise by Wavelet Method to Generate High Quality Temporal Data of Terrestrial MODIS Products, Photogrammetric Engineering & Remote Sensing, vol.73, issue.10, pp.73-1129, 2007. ,
DOI : 10.14358/PERS.73.10.1129
Reconstructing pathfinder AVHRR land NDVI time-series data for the Northwest of China, Advances in Space Research, vol.37, issue.4, pp.835-840, 2006. ,
DOI : 10.1016/j.asr.2005.08.037
Non-linear Least Squares Fitting in IDL with MPFIT, Astronomical Data Analysis Software and Systems XVII ASP Conference Series, XXX Parmesan, C Influences of species, latitudes and methodologies on estimates of phenological response to global warming, Global Change Biology, vol.13, issue.9, pp.1860-1872, 2007. ,
Measuring phenological variability from satellite imagery, Journal of Vegetation Science, vol.13, issue.5, pp.703-714, 1994. ,
DOI : 10.2307/3235884
Reconstructing cloudfree NDVI composites using Fourier analysis of time series, International Journal of Remote Sensing, vol.21, issue.9, pp.1911-1917, 2000. ,
DOI : 10.1080/014311600209814
A crop phenology detection method using time-series MODIS data, Remote Sensing of Environment, vol.96, issue.3-4, pp.3-4, 2005. ,
DOI : 10.1016/j.rse.2005.03.008
Smoothing and Differentiation of Data by Simplified Least Squares Procedures., Analytical Chemistry, vol.36, issue.8, pp.1627-1639, 1964. ,
DOI : 10.1021/ac60214a047
Comments on Smoothing and differentiation of data by simplified least square procedure, Analytical chemistry, issue.11, pp.44-1906, 1972. ,
Remote sensing data assimilation for a prognostic phenology mode, Journal of Geophysical Research, pp.1131-1150, 2008. ,
Nonlinear Noise Reduction of Chaotic Time Series Based on Multi-dimensional Recurrent Least Squares Support Vector Machines, LECTURE NOTES IN COMPUTER SCIENCE, pp.4232900-906, 2006. ,
DOI : 10.1007/11893028_100
Julian dates and introduced temporal error in remote sensing vegetation phenology studies, International Journal of Remote Sensing, vol.72, issue.20, pp.29-6045, 2008. ,
DOI : 10.1016/S0034-4257(02)00135-9
Monitoring Maize ( L.) Phenology with Remote Sensing, Agronomy Journal, vol.96, issue.4, pp.1139-1147, 2004. ,
DOI : 10.2134/agronj2004.1139
The Best Index Slope Extraction ( BISE): A method for reducing noise in NDVI time-series, International Journal of Remote Sensing, vol.53, issue.8, pp.1585-1590, 1992. ,
DOI : 10.1016/0034-4257(91)90016-Y
Using USDA Crop Progress Data for the Evaluation of Greenup Onset Date Calculated from MODIS 250-Meter Data, Photogrammetric Engineering & Remote Sensing, vol.72, issue.11, pp.72-1225, 2006. ,
DOI : 10.14358/PERS.72.11.1225
Real-time monitoring and short-term forecasting of land 16, 2006. ,
Liping Di 2, Zhiyuan Pei1 surface phenology, pp.43-49 ,
Monitoring vegetation phenology using MODIS, Remote Sensing of Environment, vol.84, issue.3, pp.471-475, 2003. ,
