Journal articles
Identifying developmental phases in the Arabidopsis thaliana rosette using integrative segmentation models
Maryline Lievre 1, 2 Christine C. Granier 1 yann Guédon 2, 3
2 VIRTUAL PLANTS - Modeling plant morphogenesis at different scales, from genes to phenotype
CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique, UMR AGAP - Amélioration génétique et adaptation des plantes méditerranéennes et tropicales
Abstract : The change in leaf size and shape during ontogeny associated with heteroblastic development is a composite trait for which extensive spatiotemporal data can be acquired using phe-notyping platforms. However, only part of the information contained in such data is exploited, and developmental phases are usually defined using a selected organ trait. We here introduce new methods for identifying developmental phases in the Arabidopsis rosette using various traits and minimum a priori assumptions. A pipeline of analysis was developed combining image analysis and statistical models to integrate morphological, shape, dimensional and expansion dynamics traits for the successive leaves of the Arabidopsis rosette. Dedicated segmentation models called semi-Markov switching models were built for selected genotypes in order to identify rosette developmental phases. Four successive developmental phases referred to as seedling, juvenile, transition and adult were identified for the different genotypes. We show that the degree of covering of the leaf abaxial surface with trichomes is insufficient to define these developmental phases. Using our pipeline of analysis, we were able to identify the supplementary seedling phase and to uncover the structuring role of various leaf traits. This enabled us to compare on a more objective basis the vegetative development of Arabidopsis mutants.
Complete list of metadata
https://hal.inria.fr/hal-01360976
Contributor : Christophe Godin Connect in order to contact the contributor
Submitted on : Tuesday, September 6, 2016 - 3:07:41 PM
Last modification on : Thursday, March 24, 2022 - 3:37:12 AM
Links full text
Identifiers
Citation
Maryline Lievre, Christine C. Granier, yann Guédon. Identifying developmental phases in the Arabidopsis thaliana rosette using integrative segmentation models. New Phytologist, Wiley, 2016, 210 (4), pp.1466-1478. ⟨10.1111/nph.13861⟩. ⟨hal-01360976⟩
Share
Metrics
Record views
188
