Study on the GPS Data De-noising Method Based on Wavelet Analysis
Signal de-noising is one of the classical problems in the field of signal processing. As a new signal processing tools, wavelet analysis, which has excellent noise performance, has caused growing concern and attention. The wavelet threshold de-noising has been researched systematacially, and the wavelet de-noising method is used on the GPS signal, which has achieved very good results.
Informatique [cs]
