A preliminary study on the method for corn yield estimation by remote sensing in north China, Quarterly Journal of Applied Meteorology, issue.6, pp.33-41, 1995. ,
Review of research advances in remote sensing monitoring of grain crop area, Transactions of the Chinese Society of Agricultural Engineering, issue.6, pp.21-166, 2005. ,
Consistency study between MODIS and TM on winter wheat plant area monitoring, Journal of Remote Sensing, issue.3, pp.11-350, 2007. ,
A simple method to improve field-level rice identification: toward operational monitoring with satellite remote sensing, Australian Journal of Experimental Agriculture, pp.379-387, 200343. ,
Mapping paddy rice agriculture in South and Southeast Asia using multi-temporal MODIS images, Remote Sensing of Environment, vol.100, issue.1, pp.95-113, 2006. ,
DOI : 10.1016/j.rse.2005.10.004
Land-use induced changes in topsoil organic carbon stock of paddy fields using MODIS and TM/ETM analysis: A case study of Wujiang County, China, Journal of Environmental Sciences, vol.20, issue.7, pp.852-858, 2008. ,
DOI : 10.1016/S1001-0742(08)62137-3
Mapping paddy fields in large areas, based on time series multi-sensors data[J]. Transactions of the CSAE, pp.26-240, 2010. ,
HJ-1 remotely sensed data and sampling method for wheat area estimation, Scientia Agricultura Sinica, issue.16, pp.43-3306, 2010. ,
Remote sensing measurement of corn planting area based on field-data[J]. Transactions of the CSAE, pp.25-147, 2009. ,
Extraction of multi-crop planting areas from MODIS data, J]. Resources Science, issue.6, pp.26-43, 2004. ,
Remote sensing monitoring of winter wheat areas using MODIS data[J]. Transactions of the CSAE, pp.23-144, 2007. ,
Monitoring planting area and growth situation of irrigation-land and dry-land winter wheat based on TM and MODIS data, J]. Transactions of the CSAE, issue.3, pp.25-103, 2009. ,
Agricultural drought monitoring based on TM and MODIS remote sensing data?a case study of HebeiProvince, Journal of Nature Disasters, vol.1714, issue.6, pp.91-95, 2008. ,
Applications of wavelet analysis to remote sensing image processing ,
Research and analysis of multi-sources remotely sensed imagery fusion on the basis of wavelet transform technique. Modern Surveying and Mapping, pp.39-41, 2009. ,
Study on 3S-Based Estimation of Cotton-growing Area, Arid Zone Research, vol.25, issue.2, pp.207-211, 2008. ,
Improved minimum distance classifier ? weighted minimum distance classifier ,
Measurement of sown area of winter wheat based on per-field classification and remote sensing imagery[J], Journal of Remote Sensing, vol.14, issue.4, pp.789-805, 2010. ,
