The Self-adaptive Adjustment Method of Clustering Center in Multi-spectral Remote Sensing Image Classification of Land Use - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
As one kind of remote sensing images of land use composed by various categories of surface objects difficult to obtain multi-distribution model of class spectral feature, analyzing the spectral characteristics of LU of multispectral RS imagery, this paper presents a self-adaptive adjustment of clustering center method. Depending on the intercepted situation of the cluster centers between different features to conduct split, the sub-centers obtained are as the sub-category features and the cluster centers assemble to characterize category model which is better to deal with the problems of LU category composed by various surface objects and category model not satisfying multivariate normal distribution. As there are much differences between the many centers features in the unit of category area, so the selection of training area and the determinants of rules are easy. The results of experiment indicate that the LU classification accuracy is increased between 4% and 6% with this method.
978-3-642-27278-3_57_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01361030 , version 1 (06-09-2016)
Paternité
Shujing Wan, Chengming Zhang, Jiping Liu, Yong Wang, Hui Tian, et al.. The Self-adaptive Adjustment Method of Clustering Center in Multi-spectral Remote Sensing Image Classification of Land Use. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. pp.559-568, ⟨10.1007/978-3-642-27278-3_57⟩. ⟨hal-01361030⟩
142 Consultations
49 Téléchargements
