B. A. Cox, A review of dissolved oxygen modeling techniques for lowland rivers. The Science of the Total Environment 314-316, pp.303-334, 2003.
M. A. Best, A. W. Wither, and S. Coates, Dissolved oxygen as a physico-chemical supporting element in the Water Framework Directive, Marine Pollution Bulletin, vol.55, issue.1-6, pp.53-64, 2007.
DOI : 10.1016/j.marpolbul.2006.08.037
I. Helm, L. Jalukse, M. Vilbaste, and I. Leito, Micro-Winkler titration method for dissolved oxygen concentration measurement, Analytica Chimica Acta, vol.648, issue.2, pp.167-173, 2009.
DOI : 10.1016/j.aca.2009.06.067
Y. Zhang and D. Johnson, Supersaturated dissolved oxygen measured by the phosphorescence decay rate, Sensors and Actuators B: Chemical, vol.96, issue.1-2, pp.379-384, 2003.
DOI : 10.1016/S0925-4005(03)00573-2
J. Lakowicz, Principles of Fluorescence Spectroscopy Kluwer Academic, 1999.
S. Lee, Y. B. Shin, H. Pyo, and S. H. Park, Highly Sensitive Optical Oxygen Sensing Material: Thin Silica Xerogel Doped with Tris(4,7-diphenyl-1,10-phenanthroline)ruthenium, Chemistry Letters, vol.30, issue.4, pp.310-311, 2001.
DOI : 10.1246/cl.2001.310
M. M. Choi, X. , and D. , Linear calibration function of luminescence quenching-based optical sensor for trace oxygen analyses, Analyst, vol.224, pp.695-698, 1999.
A. K. Mcevoy, C. Mcdonagh, and B. D. Maccraith, Dissolved oxygen sensor based on fluorescence quenching of oxygen-sensitive ruthenium complexes immobilized in sol???gel-derived porous silica coatings, The Analyst, vol.3, issue.42, pp.785-788, 1996.
DOI : 10.1039/AN9962100785
A. Campbell and D. Uttamchandani, Optical dissolved oxygen lifetime sensor based on sol-gel immobilization, IEE Proc.-Sci. Meas. Technol, p.151, 2004.
X. Wang, Y. Ren, and S. Chen, On-line DO survey meter based on optic fiber sensor. Mechanical ? Electrical Engineering Magazine26, pp.89-91, 2009.
Z. Lu and X. Zhao, Development of the fluorescence quenching seawater dissolved oxygen detector based on AT89S52, Journal of Hefei University of Technology, vol.30, pp.174-177, 2007.
X. Xiong, D. Xiao, and M. M. Choi, Dissolved oxygen sensor based on fluorescence quenching of oxygen-sensitive ruthenium complex immobilized on silica???Ni???P composite coating, Sensors and Actuators B: Chemical, vol.117, issue.1, pp.172-176, 2006.
DOI : 10.1016/j.snb.2005.11.044
J. Bharathibai, A. Basu, A. R. Thirumurugan, C. Dinesh, K. S. Anandan et al., Optical oxygen sensor coating based on the fluorescence quenching of a new pyrene derivative, Sensors and Actuators B, vol.104, pp.15-22, 2005.
R. N. Gillanders, M. C. Tedford, P. J. Crilly, and R. T. Bailey, A composite sol???gel/fluoropolymer matrix for dissolved oxygen optical sensing, Journal of Photochemistry and Photobiology A: Chemistry, vol.163, issue.1-2, pp.193-199, 2004.
DOI : 10.1016/j.jphotochem.2003.11.003
