Finite element analysis on mechanical properties of castor-capsule, Journal of Jiangsu University, vol.31, issue.4, pp.383-87, 2010. ,
Finite element modeling and mechanical analysis of hickory kernel, Agriculture equipment and vehicle engineering, pp.6-9, 2010. ,
Technology for breaking walnut shell based on finite element analysis, Transactions of the CSAE, vol.21, issue.3, pp.185-188, 2005. ,
Analysis of finite element method for threshing gingko fruit shell, Transactions of the CSAE, vol.19, issue.4, pp.58-61, 2003. ,
Mechanical characteristics and the finite element analysis of grapes, Transactions of the CSAE, vol.21, issue.3, pp.7-10, 2005. ,
Research on Optimal Crack Position of Lotus Seed based on FEA AND experiment, 2005. ,
