Abstract : By studying the existing algorithms for background value in GM(1,1), a nonlinear optimization model of GM(1,1) based on multi-parameter background value is given. The paper uses the invertible matrix of the parameter to optimize and estimate the parameters $\hat{a}$; in addition, the parameter estimate $\hat{a}$ obtained from the multi-parameter background value has higher prediction accuracy, thus overcoming the restriction on the prediction based on the fixed average background value in other literatures. the simulated values obtained by the optimized model (NOGM(1,1)) are more precise, and the maximum error is reduced by 15%. The nonlinear optimization model of GM(1,1) based on multi-parameter background value provides algorithms for further study of GM(1,1) model.
Daoliang Li; Yingyi Chen. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. Springer, IFIP Advances in Information and Communication Technology, AICT-370, pp.15-19, 2012, Computer and Computing Technologies in Agriculture V. 〈10.1007/978-3-642-27275-2_2〉
https://hal.inria.fr/hal-01361113
Contributeur : Hal Ifip
Soumis le : mardi 6 septembre 2016 - 17:02:26
Dernière modification le : mardi 6 septembre 2016 - 17:40:35
Document(s) archivé(s) le : mercredi 7 décembre 2016 - 13:36:23
Tangsen Zhan, Hongyan Xu. Nonlinear Optimization of GM(1,1) Model Based on Multi-parameter Background Value. Daoliang Li; Yingyi Chen. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. Springer, IFIP Advances in Information and Communication Technology, AICT-370, pp.15-19, 2012, Computer and Computing Technologies in Agriculture V. 〈10.1007/978-3-642-27275-2_2〉. 〈hal-01361113〉
