Modeling of standing column well in ground source heat pump system, 2004. ,
The design and test of greenhouse solar energy heating system, Acta Energiae Solaris Sinica, vol.25, issue.3, pp.305-309, 2004. ,
Three-years operation experience of a ground source heat pump system in Northern Greece, Energy and Buildings, vol.39, issue.3, pp.328-334, 2007. ,
DOI : 10.1016/j.enbuild.2006.08.002
Exergetic evaluation of biomass gasification, Energy, vol.32, issue.4, pp.568-574, 2007. ,
DOI : 10.1016/j.energy.2006.06.024
A finite line-source model for boreholes in geothermal heat exchangers, Heat Transfer?Asian Research, vol.104, issue.7, pp.31-558, 2002. ,
DOI : 10.1002/htj.10057
Improved underground heat exchanger by using no-dig method for space heating and cooling, Renewable Energy, vol.32, issue.3, pp.480-495, 2007. ,
DOI : 10.1016/j.renene.2006.01.020
Simulation and experiment on the thermal performance of U-vertical ground coupled heat exchanger, Applied Thermal Engineering, vol.26, issue.14-15, pp.1564-1571, 2006. ,
DOI : 10.1016/j.applthermaleng.2005.12.007
Capacity-controlled ground source heat pumps in hydronic heating systems, International Journal of Refrigeration, vol.30, issue.2, pp.221-229, 2007. ,
DOI : 10.1016/j.ijrefrig.2006.08.008
Investigation and analysis on utilization of ground source heat pump in China. Construction and Design for Project, pp.16-19, 2006. ,
Energy consumption and economic analysis of ground source heat pump used in greenhouse in Beijing, Transactions of the CSAE, vol.26, issue.3, pp.249-254, 2010. ,
Application of ground-source heat pump and floor heating system to greenhouse heating in winter, Transactions of the CSAE, vol.24, issue.12, pp.145-149, 2008. ,
The role of exergy in energy policy making, Energy Policy, vol.30, issue.2, pp.137-149, 2002. ,
DOI : 10.1016/S0301-4215(01)00079-9
Emergy and exergy analyses: Complementary methods or irreducible ideological options?, Energy, vol.30, issue.10, pp.1953-1988, 2005. ,
DOI : 10.1016/j.energy.2004.08.003
Energy efficiency, no: It's exergy efficiency!, International Journal of Hydrogen Energy, vol.32, issue.17, pp.4109-4111, 2007. ,
DOI : 10.1016/j.ijhydene.2007.08.008
Refrigeration Compressor, 2002. ,
Brief Manual for Air Conditioning Worker, 1999. ,
Engineering Thermodynamics, 2001. ,
Thermodynamic irreversibilities and exergy balance in combustion processes, Progress in Energy and Combustion Science, vol.34, issue.3, pp.351-376, 2008. ,
DOI : 10.1016/j.pecs.2007.09.001
Exergoeconomic analysis of a solar assisted ground-source heat pump greenhouse heating system, Applied Thermal Engineering, vol.25, issue.10, pp.1459-147, 2005. ,
DOI : 10.1016/j.applthermaleng.2004.09.015
Work and entropy production aspects of irreversible processes in closed and steady-state open systems, Exergy, An International Journal, vol.2, issue.3, pp.192-205, 2002. ,
DOI : 10.1016/S1164-0235(01)00049-8
A comparative study on exergetic assessment of two ground?source (geothermal) heat pump systems for residential applications, Building and Environment, vol.42, pp.2004-2013, 2007. ,
A parametrical study on the energetic and exergetic assessment of a solar-assisted vertical ground-source heat pump system used for heating a greenhouse, Building and Environment, vol.42, issue.1, pp.11-24, 2007. ,
DOI : 10.1016/j.buildenv.2005.07.003
The thermodynamic analysis of water source heat pump. Energy Conservation Technology, pp.29-32, 2004. ,
