Abstract : The impact-based grain flow sensor is widely used in the combine harvester yield monitor systems to measure the crop yield .but its accuracy wrecked by false signal of excessive natural vibration. A step response experiment was carried to identify the math function of the sensor. Experiment found that the math function of the sensor was a second-order vibration system, its Damping Ratio was 0.037, and its natural frequency was 125Hz, the overshoot reached 20%.To reduce the effect of the overshoot and natural vibration signal on the measurement accuracy, a dynamic compensation algorithm was designed with the series correction method. Step response experiment showed that the overshoot of the compensated sensor was reduced from 20% to 2%.
https://hal.inria.fr/hal-01361140 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, September 6, 2016 - 5:07:42 PM Last modification on : Tuesday, September 6, 2016 - 5:40:17 PM Long-term archiving on: : Wednesday, December 7, 2016 - 2:07:02 PM
