Research progress in farming information acquisition technique for precision agricult ure, Transactions of Agricultural Engineering, vol.2006, issue.221, pp.167-173 ,
The Technique of Crop Yield Monitor and Key Equipment, Agriculture Network Information, 2004. ,
A Review of Combine Sensors for Precision Farming, Precision Agriculture?2002, pp.169-182 ,
Experimental Research on Grain flow measurement System Using an Impact sensor, J] Transactions of Agricultural Machinery?2001?, pp.48-50 ,
Experiment Research of Grain Mass Flow Sensor Based on Impact, Transactions of Agricultural Machinery? 2005?, pp.82-84 ,
Impact-based grain yield sensor with compensation for vibration and drift, Journal of the JSAM, vol.64, issue.5, pp.108-115, 2002. ,
COMPARISON OF IMPACT PLATE AND TORQUE-BASED GRAIN MASS FLOW SENSORS, Transactions of the ASAE, vol.47, issue.4, pp.47-1337, 2004. ,
DOI : 10.13031/2013.16557
A DIAPHRAGM IMPACT SENSOR FOR MEASURING COMBINE GRAIN FLOW, Applied Engineering in Agriculture, vol.15, issue.6, pp.639-642, 1999. ,
DOI : 10.13031/2013.5830
Mass flow measurements with a curved plate at the exit of an elevator, Proceedings of the 3rd International Conference on Precision Agriculture, 1996. ,
An impact type flow rate sensor for combines, International Conference on Agricultural Engineering. Uppsala?Sweden, pp.15-16, 1992. ,
Laboratory performance of a yield monitor, J]?Applied Enginering in Agriculture?, vol.15, issue.03, pp.189-195 ,
Combine yield monitor test facility development and initial monitoring test, J]?Applied Engineering in Agriculture?19, issue.01, pp.5-12 ,
Grain Yield Monitor Flow Sensor Accuracy for Simulated Varying Field Slopes, Applied Engineering in Agriculture, vol.25, issue.1, pp.15-21, 2009. ,
DOI : 10.13031/2013.25425
Yield monitor accuracy successful farming magazine case study, J]?Applied Engineering in Agriculture?, vol.18, issue.02, pp.147-151 ,
Damping Design of Impact-based Grain Yield Sensor, Transactions of the Chinese Society for Agricultural Machinery? 2005?36, pp.121-123 ,
Damping desige and signal proscession of the yield sensor on grain combine, Progress of information technology in Agriculture, proceedings of the 4th international symposium on intelligent information technology in agriculture(ISIITA), 2007. ,
Signal processing method for impact-based grain mass flow sensor with parallel beam load cell [J]. Transactions of the Chinese Society of Agricultural Engineering, pp.183-187, 2008. ,
Experiment of Dual-plates Differential Impact-based Grain Flow Sensor, Transactions of the Chinese Society for Agricultural Machinery, pp.41172-173, 2010. ,
