Introduction on the Capacitor Sensors Method for a Moisture Measuring Instrument on Line in Grains, Journal of ChangChun University of Science ,
Principle and Application of Capacity Sensor?Modern Electronic Technique, 2003715078. ,
Data Processing of Moisture Content Measurement Based on Data Fusion, Journal of Liaoning Insitute of Technology, vol.26, issue.3, pp.158-160, 2006. ,
Multiquadric Equations of Topography and Other Irregualr Sufaces, Journal of Geophysics Research, pp.1905-1915, 1987. ,
Interpolation using surface splines., Journal of Aircraft, vol.9, issue.2, pp.189-191, 1972. ,
DOI : 10.2514/3.44330
Fast Learning in Networks of Locally-Tuned Processing Units, Neural Computation, vol.1, issue.2, pp.281-294, 1989. ,
DOI : 10.1109/MASSP.1987.1165576
Radial basis function network configuration using genetic algorithms, Neural Networks, vol.8, issue.6, pp.877-890, 1995. ,
DOI : 10.1016/0893-6080(95)00029-Y
Study on RBF Neural Network Improvement and its Application, 2008. ,
en and Zhu shixin, Matrix Theory and its Application, 2005. ,
