Non-fragile guaranteed cost control for uncertain neutral dynamic systems with time-varying delays in state and control input, Chaos, Solitons & Fractals, vol.31, issue.4, pp.889-899, 2007. ,
DOI : 10.1016/j.chaos.2005.10.080
On delay-dependent stability for linear neutral systems, Automatica, vol.39, issue.2, pp.255-261, 2003. ,
DOI : 10.1016/S0005-1098(02)00227-3
An LMI Approach to the<tex>$H_infty $</tex>Filter Design for Uncertain Systems With Distributed Delays, IEEE Transactions on Circuits and Systems II: Express Briefs, vol.51, issue.4, pp.195-201, 2004. ,
DOI : 10.1109/TCSII.2003.822432
Robust control of uncertain distributed delay systems with application to the stabilization of combustion in rocket motor chambers, Automatica, vol.38, issue.3, pp.487-497, 2002. ,
DOI : 10.1016/S0005-1098(01)00232-1
A delay-dependent approach to robust H ? filtering for uncertain distributed delay systems, IEEE Transactions on Signal Processing, vol.53, issue.10, pp.3764-3772, 2005. ,
Evaluation of quadratic cost functionals for a class of distributed-delay systems, IET Control Theory & Applications, vol.1, issue.1, pp.313-319, 2007. ,
DOI : 10.1049/iet-cta:20050326
Robust Stabilization of the Distributed Parameter System With Time Delay via Fuzzy Control, IEEE Transactions on Fuzzy Systems, vol.16, issue.3, pp.567-584, 2008. ,
DOI : 10.1109/TFUZZ.2007.896233
Robust guaranteed cost control for uncertain linear differential systems of neutral type, Applied Mathematics and Computation, vol.140, issue.2-3, pp.523-535, 2003. ,
DOI : 10.1016/S0096-3003(02)00250-3
LMI control toolbox user's guide, The Math Works Inc, 1995. ,
Non-fragile positive real control for uncertain linear neutral delay systems, Systems & Control Letters, vol.52, issue.1, pp.59-74, 2004. ,
DOI : 10.1016/j.sysconle.2003.11.001
Nonfragile <formula formulatype="inline"><tex>$H_{\infty}$</tex></formula> Control for Uncertain Neutral Systems With Time-Varying Delays via the LMI Optimization Approach, IEEE Transactions on Systems, Man and Cybernetics, Part B (Cybernetics), vol.37, issue.2, pp.493-499, 2007. ,
DOI : 10.1109/TSMCB.2006.885311
