Abstract : Chlorophyll-a was regarded as the important indicator to describe the marine primary production because the chlorophyll a content of phytoplankton in the ocean is related to its photosynthesis production. The concentration of chlorophyll a is also the major parameter to evaluate marine water quality, organic pollution and detect the fishing ground, and the temporal and spatial variation of chlorophyll a contains the basic information of sea areas. Based on the spectral characteristics of chlorophyll fluorescence, this document recommends a new dual optical detecting instrument for the measurement of chlorophyll-a concentration, the microcontroller MSP430F149 as the key control module, by controlling the ultra-high brightness LED which wavelength is 450nm to excite chlorophyll a to produce the fluorescent signal about 680nm , at the same time this LED is used as reference light, the dual-optical structure exclude the light fluctuations due to the impact of test results. At last, we get the relationship between relative fluorescence intensity and chlorophyll-a concentration with the spectrophotometer, we find the system has the good linear consistency when measures the low concentrations of chlorophyll-a.
https://hal.inria.fr/hal-01361175 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, September 6, 2016 - 5:16:02 PM Last modification on : Tuesday, September 6, 2016 - 5:40:15 PM Long-term archiving on: : Wednesday, December 7, 2016 - 2:18:37 PM
Cong Wang, Daoliang Li, Lingxian Zhang, Qisheng Ding, Zetian Fu. A Portable Measurement Instrument for the Measurement of Water Body Chlorophyll-a in the Support of Fluorescence Detection. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. pp.484-494, ⟨10.1007/978-3-642-27275-2_54⟩. ⟨hal-01361175⟩
