Optimization Nonlocal Image Restoration with Bilateral Variance Estimation : A Low-Rank Approach, Statistics IEEE Trans. Image Process, vol.22, issue.2 2, pp.700-711, 2004. ,
From learning models of natural image patches to whole image restoration, 2011 International Conference on Computer Vision, pp.479-486, 2011. ,
DOI : 10.1109/ICCV.2011.6126278
Weighted Nuclear Norm Minimization with Application to Image Denoising, 2014 IEEE Conference on Computer Vision and Pattern Recognition, pp.2862-2869, 2014. ,
DOI : 10.1109/CVPR.2014.366
UniHIST: A Unified Framework for Image Restoration With Marginal Histogram Constraints, Proc. IEEE Conf. Computer Vis. and Pattern Recognit, pp.3753-3761, 2015. ,
Bilateral filtering for gray and color images, Sixth International Conference on Computer Vision (IEEE Cat. No.98CH36271), pp.839-846, 1998. ,
DOI : 10.1109/ICCV.1998.710815
Nonlinear total variation based noise removal algorithms, Physica D: Nonlinear Phenomena, vol.60, issue.1-4, pp.259-268, 1992. ,
DOI : 10.1016/0167-2789(92)90242-F
Image denoising using scale mixtures of gaussians in the wavelet domain, IEEE Transactions on Image Processing, vol.12, issue.11, pp.1338-1351, 2003. ,
DOI : 10.1109/TIP.2003.818640
A Non-Local Algorithm for Image Denoising, 2005 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (CVPR'05), pp.60-65, 2005. ,
DOI : 10.1109/CVPR.2005.38
Bayesian Inference for Neighborhood Filters with Application in Denoising, Proc. IEEE Conf. Computer Vis. and Pattern Recognit, pp.1657-1665, 2015. ,
Patch Group Based Nonlocal Self-Similarity Prior Learning for Image Denoising, 2015 IEEE International Conference on Computer Vision (ICCV), 2015. ,
DOI : 10.1109/ICCV.2015.36
Image Denoising by Sparse 3-D Transform-Domain Collaborative Filtering, IEEE Transactions on Image Processing, vol.16, issue.8, pp.2080-2095, 2007. ,
DOI : 10.1109/TIP.2007.901238
Color Image Denoising via Sparse 3D Collaborative Filtering with Grouping Constraint in Luminance-Chrominance Space, 2007 IEEE International Conference on Image Processing, pp.313-316, 2007. ,
DOI : 10.1109/ICIP.2007.4378954
Image Denoising Using the Higher Order Singular Value Decomposition, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.35, issue.4, pp.849-862, 2013. ,
DOI : 10.1109/TPAMI.2012.140
Separating Sginal from Noise Using Patch recurrence across scales, Proc. IEEE Conf. Computer Vis. and Pattern Recognit, pp.1195-1202, 2013. ,
Texture Enhanced Image Denoising via Gradient Histogram Preservation, 2013 IEEE Conference on Computer Vision and Pattern Recognition, pp.1203-1210, 2013. ,
DOI : 10.1109/CVPR.2013.159
<tex>$rm K$</tex>-SVD: An Algorithm for Designing Overcomplete Dictionaries for Sparse Representation, IEEE Transactions on Signal Processing, vol.54, issue.11, pp.4311-4322, 2006. ,
DOI : 10.1109/TSP.2006.881199
Sparse Representation for Color Image Restoration, IEEE Transactions on Image Processing, vol.17, issue.1, pp.53-69, 2008. ,
DOI : 10.1109/TIP.2007.911828
Non-local sparse models for image restoration, 2009 IEEE 12th International Conference on Computer Vision, pp.2272-2279, 2009. ,
DOI : 10.1109/ICCV.2009.5459452
Nonlocally Centralized Sparse Representation for Image Restoration, IEEE Transactions on Image Processing, vol.22, issue.4, pp.1620-1630, 2013. ,
DOI : 10.1109/TIP.2012.2235847
Global Image Denoising, IEEE Transactions on Image Processing, vol.23, issue.2, pp.755-768, 2014. ,
DOI : 10.1109/TIP.2013.2293425
Fields of Experts, International Journal of Computer Vision, vol.27, issue.2, pp.205-229, 2009. ,
DOI : 10.1007/s11263-008-0197-6
Shrinkage Fields for Effective Image Restoration, 2014 IEEE Conference on Computer Vision and Pattern Recognition, pp.2774-2781, 2014. ,
DOI : 10.1109/CVPR.2014.349
On learning optimized reaction diffusion processes for effective image restoration, 2015 IEEE Conference on Computer Vision and Pattern Recognition (CVPR), pp.5261-5269, 2015. ,
DOI : 10.1109/CVPR.2015.7299163
Image denoising: Can plain neural networks compete with BM3D?, 2012 IEEE Conference on Computer Vision and Pattern Recognition, pp.2392-2399, 2012. ,
DOI : 10.1109/CVPR.2012.6247952
Noise Estimation from a Single Image, Proc. IEEE Conf. Computer Vis. and Pattern Recognit, pp.901-908, 2006. ,
Estimation of Signal-Dependent Noise Level Function in Transform Domain via a Sparse Recovery Model, IEEE Transactions on Image Processing, vol.24, issue.5, 2015. ,
DOI : 10.1109/TIP.2015.2405417
Learning How to Combine Internal and External Denoising Methods, Pattern Recognition, pp.121-130, 2013. ,
DOI : 10.1007/978-3-642-40602-7_13
CID: Combined Image Denoising in Spatial and Frequency Domains Using Web Images, 2014 IEEE Conference on Computer Vision and Pattern Recognition, pp.2933-2940, 2014. ,
DOI : 10.1109/CVPR.2014.375
Image Denoising by Exploring External and Internal Correlations, IEEE Transactions on Image Processing, vol.24, issue.6 ,
DOI : 10.1109/TIP.2015.2412373
Image denoising using cloud images, Applications of Digital Image Processing XXXVI, 2013. ,
DOI : 10.1117/12.2022506
Image Quality Assessment: From Error Visibility to Structural Similarity, IEEE Transactions on Image Processing, vol.13, issue.4, 2004. ,
DOI : 10.1109/TIP.2003.819861
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.11.2477
Enhancing Sparsity by Reweighted ??? 1 Minimization, Journal of Fourier Analysis and Applications, vol.7, issue.3, pp.877-905, 2008. ,
DOI : 10.1007/s00041-008-9045-x
Deconvolution using natural image priors, 2007. ,
Dr. H. Yahia received the Doctorat ode 3eme cycle from University Paris 11 (Orsay) and the HDR (Habilitation Diriger des Recherches) form University Paris 13. He is specialized in non-linear signal processing and the analysis of complex signals and systems using advanced nonlinear physics Dr, Dr. H. Yahia has also made substantial contributions in Computer Graphics and Image Processing. Dr. H. Yahia is developing strong collaboration with the LEGOS Laboratory in Toulouse (UMR CNRS 55 66) as well ICM-CSIC in Barcelona, and also IIT Roorkee in India (Associated team OPTIC with Prof. Dharmendra Singh). He is also involved in many contract with the French spatial agency CNES and the European Spatial Agency ,
He is a member of the editorial board of journals in signal processing or complex systems and has been supervising more than 10 PhD students. Driss Aboutajdine received the Doctorat de 3me Cycle and the Doctorat d'Etat-es-Sciences degrees in signal processing from the Mohammed V-Agdal University first as an assistant professor, then as an associate professor in 1985, and full Professor since 1990. Over 35 years, he developed teaching and research activities covering various topics of signal and image processing, wireless communication and pattern recognition which allow him to advise more than 50 Ph.D. theses and publish over 200 journal papers and conference communications. He succeeded to found and manage since, respectively the LRIT Laboratory and the Centre of Excellence of Information & Communication Technology (pole de competences STIC) which gathers more than 30 research laboratories from all Moroccan universities and including industrial partners as well, 1978. ,
