SpecCert: Specifying and Verifying Hardware-based Software Enforcement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Over time, hardware designs have constantly grown in complexity and modern platforms involve multiple interconnected hardware components. During the last decade, several vulnerability disclosures have proven that trust in hardware can be misplaced. In this article, we give a formal definition of Hardware-based Security Enforcement (HSE) mechanisms, a class of security enforcement mechanisms such that a software component relies on the underlying hardware platform to enforce a security policy. We then model a subset of a x86-based hardware platform specifications and we prove the soundness of a realistic HSE mechanism within this model using Coq, a proof assistant system.
speccert-fm2016.pdf (450.28 Ko) Télécharger le fichier
hal-01361422 , version 1 (25-05-2018)
Thomas Letan, Pierre Chifflier, Guillaume Hiet, Pierre Néron, Benjamin Morin. SpecCert: Specifying and Verifying Hardware-based Software Enforcement. 21st International Symposium on Formal Methods (FM 2016), Nov 2016, Limassol, Cyprus. ⟨10.1007/978-3-319-48989-6_30⟩. ⟨hal-01361422⟩
310 Consultations
185 Téléchargements
