Uniform sampling in a structured branching population - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We are interested in the dynamic of a structured branching population where the trait of each individual moves according to a Markov process. The rate of division of each individual is a function of its trait and when a branching event occurs, the trait of the descendants at birth depends on the trait of the mother and on the number of descendants. In this article, we explicitly describe the penalized Markov process, named auxiliary process, corresponding to the dynamic of the trait along the spine by giving its associated infinitesimal generator. We prove a Many-to-One formula and a Many-to-One formula for forks. Furthermore, we prove that this auxiliary process characterizes exactly the process of the trait of a uniformly sampled individual in the large population approximation. We detail three examples of growth-fragmentation models: the linear growth model, the exponential growth model and the parasite infection model.
tempsfixe_rev.pdf (581.35 Ko) Télécharger le fichier
arbre_forks1.pdf (2.7 Ko) Télécharger le fichier
arbre_forks1.pdf_tex (2.06 Ko) Télécharger le fichier
arbre_forks2.pdf (4.03 Ko) Télécharger le fichier
arbre_forks2.pdf_tex (2.06 Ko) Télécharger le fichier
histo2-crop.pdf (16.97 Ko) Télécharger le fichier
hal-01362366 , version 1 (19-09-2016)
hal-01362366 , version 2 (24-09-2017)
hal-01362366 , version 3 (07-03-2018)
hal-01362366 , version 4 (19-11-2018)
Aline Marguet. Uniform sampling in a structured branching population. 2017. ⟨hal-01362366v2⟩
340 Consultations
167 Téléchargements
