Numerical solution of acoustic propagation problems using linearized euler equations, pp.22-29, 2000. ,
Acoustic perturbation equations based on flow decomposition via source filtering, Journal of Computational Physics, vol.188, issue.2, pp.365-398, 2003. ,
DOI : 10.1016/S0021-9991(03)00168-2
Perturbed Compressible Equations for Aeroacoustic Noise Prediction at Low Mach Numbers, AIAA Journal, vol.43, issue.8, pp.1716-1724, 2005. ,
DOI : 10.2514/1.3001
Linearized acoustic perturbation equations for low Mach number flow with variable density and temperature, Journal of Computational Physics, vol.224, issue.1, pp.352-364, 2007. ,
DOI : 10.1016/j.jcp.2007.02.022
Computational aeroacoustics applications based on a discontinuous galerkin method, Comptes rendus de l'Académie des sciences -Serie IIb -Mécanique, pp.333-676, 2005. ,
Application of a Discontinuous Galerkin Method to Predict Airframe Noise, 15th AIAA/CEAS Aeroacoustics Conference (30th AIAA Aeroacoustics Conference), 2009. ,
DOI : 10.2514/6.2009-3175
Coupled Discontinuous Galerkin/Finite Difference Solver on Hybrid Meshes for Computational Aeroacoustics, AIAA Journal, vol.50, issue.2, pp.338-349, 2012. ,
DOI : 10.2514/1.J051110
APPLICATION OF DISCONTINUOUS GALERKIN SPECTRAL METHOD ON HEXAHEDRAL ELEMENTS FOR AEROACOUSTIC, Journal of Computational Acoustics, vol.17, issue.02, pp.175-196, 2009. ,
DOI : 10.1142/S0218396X09003914
URL : https://hal.archives-ouvertes.fr/hal-00403787
On a Finite-Element Method for Solving the Three-Dimensional Maxwell Equations, Journal of Computational Physics, vol.109, issue.2, pp.222-237, 1993. ,
DOI : 10.1006/jcph.1993.1214
Analyse mathmatique de l'quation de galbrun en coulement uniforme, Comptes Rendus de l'Acadmie des Sciences -Srie IIB -Mcanique, pp.329-601, 2001. ,
Non spurious spectral-like element methods for Maxwell's equations, J. Comp. Math, vol.25, issue.3, pp.282-302, 2007. ,
Linearized perturbed compressible equations for low Mach number aeroacoustics, Journal of Computational Physics, vol.218, issue.2, pp.702-719, 2006. ,
DOI : 10.1016/j.jcp.2006.03.003
Mixed and Hybrid Finite Element Methods, 1991. ,
DOI : 10.1007/978-1-4612-3172-1
An Analysis of New Mixed Finite Elements for the Approximation of Wave Propagation Problems, SIAM Journal on Numerical Analysis, vol.37, issue.4, pp.1053-1084, 2000. ,
DOI : 10.1137/S0036142998345499
URL : https://hal.archives-ouvertes.fr/hal-01443182
Numerical solution of saddle point problems, Acta Numerica, vol.14, pp.1-137, 2005. ,
DOI : 10.1017/S0962492904000212
MIXED FINITE ELEMENTS WITH MASS-LUMPING FOR THE TRANSIENT WAVE EQUATION, Journal of Computational Acoustics, vol.08, issue.01, pp.171-188, 2000. ,
DOI : 10.1142/S0218396X0000011X
Advanced spectral finite element method for computational acoustics in the mid-frequency range, Proceedings of the ISMA 2010, 2010. ,
Spectral finite elements for computational aeroacoustics using acoustic pertrubation equations, Journal of Computational Acoustics, vol.20, issue.2 ,
A mixed finite element method for 2-nd order elliptic problems, Lecture Notes in Mathematics, vol.9, pp.292-315, 1977. ,
DOI : 10.1007/BF01436186
Streamline upwind/Petrov-Galerkin formulations for convection dominated flows with particular emphasis on the incompressible Navier-Stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.32, issue.1-3, pp.199-259, 1982. ,
DOI : 10.1016/0045-7825(82)90071-8
Skew-symmetric form of convective terms and fully conservative finite difference schemes for variable density low-Mach number flows, Journal of Computational Physics, vol.229, issue.2, pp.276-300, 2010. ,
DOI : 10.1016/j.jcp.2009.09.021
DISCONTINUOUS GALERKIN METHODS FOR FIRST-ORDER HYPERBOLIC PROBLEMS, Mathematical Models and Methods in Applied Sciences, vol.14, issue.12, pp.1893-1903, 2004. ,
DOI : 10.1142/S0218202504003866
Benchmark problems and solutions, in: ICASE/LaRC Workshop on Benchmark Problems in Computational Aeroacoustics, 1995. ,
Fluid?structure?acoustic interaction algorithms and implementations using the finite element method, 2010. ,
Stable matched layer for the conservation equations of acoustics in the time domain, Journal of Computational Acoustics, vol.20, issue.1 ,
Parallel CFD simulation of flow in a 3d model of vibrating human vocal folds, Computers & Fluids (0), article in press ,
